Question about Motorola Mobility RAZR V3
Keypad troubleshooting When I open my phone buttons just start "being pressed" and won't stop. Based on reading other replies it sounds like something to do with the keypad. How do you open the keypad on a RAZR?
  • 6 more comments
  • sakamoto Nov 18, 2007
    Every once in a while, The phone goes berserk, and all the buttons I press make it start a voice recording. Only way I've been able to fix is to take out the battery for a few hours. I think it has something to do with keypad shortcuts.
  • k8may17 Nov 23, 2007
    when i open my phone it just goes crazy and starts with a bunch of 444444444444####'s and then the volume gous up and down. cant do anything except shut it off??? please help
  • Anonymous Nov 23, 2007
    my power off button is not working
  • Anonymous Nov 24, 2007
    My keypad buttons aren't working except for the Power Button. I can't make any outgoing calls and can only receive calls. It is really annoying! Help!
  • jbabke Feb 06, 2008
    the on / oof button does not work. It happened gradually. If I take out the battery and press the backside of the power button, it turns on when i replace the battery. I can only shut it off by removing the battery. Please help
  • tiger5297 Feb 06, 2008
    I can turn Phone on but my Key pad freezes and i cannot do anything
  • Anonymous Feb 14, 2008
    I have the same problem with the buttons all seeming to be pressed when I turn on the phone. It seems to be mostly the 3 button. It won't take any input from me
  • beeps77 Jun 08, 2008
    i was texting when all of a sudden my razor phone said voice name not stored in phone and it constantly kept saying that. Then my phone would freeze up and get a blank screen. All i have done so far is turn off my phone.
The light under my key pad won't light up. I have a Motorola Razr V3 Cellular Phone. please help. My e-mail address is [email protected]
Posted on Mar 19, 2008
I had the keypad problem I wrote about earlier. I removed the batttery and I pushed the back of the keypad where the key I had problems with, alternatively presssing on the key and the back of the key.This seemed to work perfectly, and the phone works as new, since then, (2 weeks ). Try it with your problem keys.
Posted on Feb 15, 2008
When I open my phone it seems to be stuck on the right arrow button so it goes to "IM account". I was really confused this morning because even if I click exit, it goes back to the same thing on its own. when I get a chance to press menu, it just whirls around as if I'm pressing the arrow over to choose a category but I'm not.. its weird.. probably the weirdest phone I've ever had
Posted on Feb 14, 2008
SOURCE:
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 26, 2016 | Kenmore Refrigerators
Sears troubleshooting
sounds like a power outage at some point. check batteries in remotes. re-program remotes to motor. get ladder, push square button on rear of motor then press button on remote. press remote again to check operation. repeat for second remote.
Jan 31, 2014 | Sears Craftsman LiftMaster Chamberlain...
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
WHEN I AM TYPING ON MY KEYPAD I GET A SOUND ON EACH LETTER TYPED.
go to standby mode (close the phone) slide it up and press the volume button (the ones on the left side) this should make you able to adjust the volume of the key tone. hope this answers you question.
Feb 23, 2009 | Samsung SGH-U900 Flipshot Cellular Phone
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Something wrong with my keypad
sounds like the buttons are pressing against each other and needs urgent attention as it could affect the whole keypad
Sep 27, 2008 | LG VX8300 Cellular Phone
HELP!!!
i think the keypad sensor is the problem ...
if your good at opening then just remove the handset take off the keypad check the keypad is it in good condition or not ..
if not you replace with the new one ...
& also clear if there is any obstacles in the keypad sensor ...
this will solve your problem .
it cant be the firmware problem so just do this it will be fixed ..
if you are not good at opening then just tap the phone lightly so that if there is any loose contact in the keypad with sensor it may get fixed .... otherwise you must & should open the handset & do it ...
if you are afraid then just visit the technician ...
it is just a matter of some bucks ... i think you can only do this simple thing by opening...
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
Dec 15, 2007 | Motorola Mobility RAZR V3
Setting time
Sounds like a keypad problem. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you think you or a friend may want to take a look, please reply here and I can follow up with more targeted information.
May 25, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Motorola Mobility RAZR V3 Logo
161 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
