To replace the broken light on your Broan Allure range hood, you will need to follow these steps:
- Turn off the power to the range hood by unplugging it or turning off the circuit breaker.
- Remove the filters by gently pulling them down and then out of the range hood.
- Locate the light cover and remove it by pulling it towards you.
- Use a screwdriver to remove the screws that are holding the light assembly in place.
- Carefully pull the light assembly out of the range hood.
- Replace the broken light bulb and ensure that it is securely in place.
- Reinsert the light assembly into the range hood and tighten the screws.
- Reattach the light cover by pushing it back into place.
- Replace the filters by pushing them back up into the range hood.
- Turn on the power to the range hood and test the new light to ensure it is working properly.
Note: If the light assembly is wobbly, you may need to tighten the screws that hold it in place or replace any damaged parts.
