Question about Abit KV7-V Motherboard
Loading xp home edition
I have a abit kv7-7 motherboard with 3ghz amd with 512 gig ram. Cannot get xp to load ont he hard drive it is 8gig. It starts to load, but when it comes up to repair, install, or exit it shuts off the computer. Little confused as to why.
    Problem Solver:
  • 10 Answers
I can try and suggest you check the cables from you CD-ROM, any sort of damage the CD might have. Or then again, if your Hard Drive is SATA connected, then you'll need to load the SATA controler (F6 on the windows instalation) And, in last case, either upgrade your bios or try a different CD-ROM drive unit. But I would defenatly put my money on the cables.
Posted on Sep 24, 2007
SOURCE:
How can i upgrade from windows XP professional to windows vista for free?
you can't the system resources on the xp pc required to run xp are a lot less than what is needed to run windows vista.
how much ram and how much disk space !
it says 512 Mb ram but it will run like a snail
15 Gig of free hard disk space and a 20 Gig hard drive
https://support.microsoft.com/en-au/kb/919183
DO you have an upgrade copy of Vista ?
Nov 14, 2015 | Microsoft Windows Vista Ultimate Edition
Dear Support I'm currently reconditioning an Aleinware desktop which was D.O.A. and totally non-functional and after taking it totally apart & re-seating the CPU with new Antec Silver 5 Thermal...
I don't think that you need a bios upgrade for a 'virus' infection - they generally don't go there, as modifications to the flash memory can be tricky and difficult without knowing the flash type; viruses generally affect OS areas as being much easier.
Mar 28, 2010 | Abit AV8 Motherboard
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
I am trying to set the ContigFileAllocSize t0 512
see to it that whether your motherboard have capability to support that much capacity of hdd. might be it may nt have the support.
Jun 20, 2009 | Computers & Internet
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Vista Ultimate
need at least 2 gig of ram and 160 gig hard drive to run vista
May 29, 2008 | Microsoft Windows Vista Ultimate Edition
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Mouse freezes after installation of new graphics card
first update the bios of your system.
Then remove the drivers using safe mode, Download new drivers from nvidai web site ( do not use the drivers on the vga's cd). Disable any antivirus software and try again.
Oct 24, 2007 | EliteGroup V7.5A (K7SOM+ V7.5A)...
Abit KV7-V Motherboard Logo
85 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
