Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
When i put the spool in, the cap will not stay on
I just got out my Black & Decker GH600 trimmer for the first time this year. The cap fits fine without the spool, however, when I put the spool in, with or without line, it doesn't fit tight and pops off as soon as I turn it on. The white plastic guide is in tact as far as I can tell, it moves freely.
5 Suggested Answers
  • 12 Answers
SOURCE: corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Posted on Aug 18, 2008
  • 30 Answers
SOURCE: Line ffeds to fast on grasshog gh600 model
I have GH700 model with the same problem. I changed the line from a smooth round .065" to a star-shaped .065" (Rino-Tuff from Home Depot online) solved the problem. The manual advice was bunk. Shaped lines have fixed this problem with other electric trimmers, and I've been told that Walmart carries one.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: lawn trimmer eating line
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00. Pull old level straight out with pliers, end expands to hold lever in position. Just push replacement straight in, no other parts.
Posted on Aug 14, 2010
tomgswan
  • 30 Answers
SOURCE: Black and Decker electric trimmer (grass hog)
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Posted on Jul 02, 2011
Black and Decker electric trimmer (grass hog) model GH600...eats thru line, one spool lasts about 3 minutes
Jul 02, 2011 | Black & Decker Black and Decker & Grass...
How do I change the cord in my electric Black & Decker weed trimmer? No. 8209 4.3 amps Where do I put the cord? In which direction do I wind it?
Look here (you will need Adobe Reader )
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/244137-01,GH600.pdf
Look under Operating Instructions....Spool and Line Replacement. This model is probably same as yours in that regard. Diagrams and instructions are included.
Sep 14, 2010 | Black & Decker 14" Grass Hog Xp...
String will not feed for BD grasshop Gh600 type 2
Have a problem with your B&D GH600 trimmer? Replace part LEVER, Item #29, Part #598435-00 for about $3.00 (B&D or Dewalt). Just pull old level straight out with pliers (ends expand to hold it in place) and push replacement in. No other parts.
Jul 31, 2010 | Black & Decker String Trimmer Cordless 12"...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
How do you fit a new spool?
refer to here for generic instructions of replacing the wire/string on a trimmer.
http://wiki.answers.com/Q/How_do_you_replace_a_weed_eater_trimmer_line
have a read through, it may help assist you.
Jul 21, 2009 | Black & Decker Garden
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Corded black and decker trimer
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
281 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
