Question about Garden
MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
REAR WHEELS ARE LOCKED UP. I CANNOT GET THE HYDROSTATIC DRIVE TO UNLOCK IN ORDER TO ROLL THE MOWER AROUND. WHEN I RUN THE MOWER AND TRY TO DRIVE FORWARD OR REVERSE THE TRANSMISSION ? MAKES A BAD NOISE AND THE MOWER WILL NOT MOVE. I HAVE CHECKED THE FLUID IN DRIVE UNIT AND IT APPEARS TO BE FULL. I USED THE MOWER 3 WEEKS AGO WITH NO PROBLEMS. ?
  • Anonymous Mar 30, 2014
    I have a craftsman riding mower Model # 917.275661 with 20 hp motor. When mowing down hill the hydro trans looses forward movement and I can move the speed lever to a faster speed and it will pick back up and then can move it back to the desired operating speed. This problem doesn't occure mowing up hill. Can this be low fluid level and if so can the fluid be changed (I have read that the fluid used may not be auto trans fluid, such as type F)????
    Larry
    Sniper:
  • 109 Answers
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
I have the same problem and I move the lever to release the transmission and it is still not freewheeling. If the brake is jamed will keep the transimission from freewheeling?
Posted on May 25, 2010
The parking brake is locked up m
Posted on Aug 12, 2011
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Forward is slow
need to change hydrostatic fliud and filterthat will take care of it
Oct 02, 2014 | Husqvarna "YTH26V54 54"" Briggs And...
Rear wheels are locked
Hydrostatic or not, whats your model #. If it is Hydrostatic, first! MAKE SURE YOU ARE ON FLAT GROUND before you pull the bypass lever on the transaxle. Check your manual, if not I have included a link that may help. http://www.husqvarna.com/ddoc/HUSO/HUSO2008_AAaa/HUSO2008_AAaa_YTH2246_532418529.pdf Check out page !!
Apr 09, 2014 | Craftsman 20 hp 42" Lawn Tractor
My MTD riding mower is losing power to the rear wheels when pulling an incline. It will come to a complete stop. the engine RPM and blade rotaion do not seam effected. What am I over looking?
normally sign of a failing hydrostatic transmission. if your mower has one, start looking for a new one, mower that is as a new tranny will cost more than a new mower.
Apr 04, 2011 | Mtd Drive Belt 42"
I can not get my wheels to unlock on my riding mower LXT 1000 Model # 917 272461
which wheels are you wanting to unlock if it is a hydrostatic rear end that you wanta unlock to push manually then in the back of the mower there is a rod that you pull out or push up & over to release the axle
Jun 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
May 15, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
3,501 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
