Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Campbell hausfeld air compressor will not start
Used it for spray painting and it was working fine. Went back to use it again after several weeks and it would not start. Help!!!
It should have a reset button. Try that. Out of curiosity, is the compressor near where you paint? If so, paint may have accumulated on the switch contacts. Remove the cover and check them out.
Posted on Apr 23, 2009
Campbell Hausfeld HD4200 spray gun. Will not spray plain water. no siphon effect at feeder tube. What to check?
Check for air leaks above the top of the feeder tube. If it leaks air there, then no suction. Bad gaskets often cause this.
Oct 28, 2016 | Campbell Hausfeld Air Tools & Compressors
On a Campbell Hausfeld DH5030 spray gun, there is a screw valve at the base of the unit with arrows labeled S and P for turning clockwise and counterclockwise, respectively. What is this for?
The "P" stands for pressure feed. turning it completly to this side forces air into the cup pushing the paint out.
The "S" is for siphon feed where the air through the tip sucks paint from the cup.
If your using thin materials like lacquers or polyurethane or solvent based enamels the siphon feed is used.
If your using thicker materials like water based latex or heavy stains then go with the pressure setting.
You can always go in between for some pressure with the siphon action....depends on coatings used.
Jun 22, 2011 | Campbell Hausfeld DH5300 General Purpose...
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Dec 28, 2009 | Air Tools & Compressors
How do you diagnose a Campbell Hausfeld Airless. It will not prime nor spray?
Try to fill it with water and spray. YOu may have paint buildup in the system, and will have to disassemble it to clean it
Oct 25, 2009 | Campbell Hausfeld Airless Spray Guns &...
Airless sprayer will not prime Model AL230502LX
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
Jul 12, 2009 | Campbell Hausfeld Airless Spray Guns &...
Campbell hausfeld paint sprayer has no suction
The same thing happened to me before if the paint is too thick. Another reason was when the gun toppled over and paint went into the spring and needle in which case you will have to take it apart and clean it.
Oct 18, 2008 | Campbell Hausfeld Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
452 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
