Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Craftsman 1/3 hp garage door opener which has stopped closing with the remote. I've tried to align it by loosing the lug nut and moving the sensors around, have checked the wiring for any breaks, but still can't get the receiver to show a green light. I can close it by holding down the wall button. Both sides are like that, and I actually have to hold down one of the doors as I close it, or it will pop back up. Can anyone help with this? Thank you so much!
  • sharonmeyeri Apr 22, 2009
    Thank you, Dennis - I just tried to unplug and plug back in, but it still does not solve the problem of not being able to close the door with the remote; only by holding down the wall button until it is closed.
  • dennis_lange May 11, 2010
    Have you unplugged the unit to let it reset. I beleive the reason the one keeps popping up is because of the sensitivity adjustment. All electric garage doors have a sensitivity adjustment so that if it strikes an object on the way down it will stop and open again. Try adjusting the sensitivity adjustment. If this solves the problem, please rate my solution.
    President:
  • 3,197 Answers
You have a bad logic board.
Posted on Jun 04, 2009
My garage door opener is a 3/4 craftsman and one light is yellow and the other is green. I put my hand in front of the green light and the green light went off. the other side is a yellow light and it
Hi Vickie,
The safety beam portion of the garage door opener is set up to stop the door from closing if something (car, person, etc,.) is in the doorway.
When the door is open - if you press the hard wired push button (not the wireless remote) the door will either close until shut completely, or begin to close and reverse direction as soon as you let go of the button. When this happens, it *usually* means that a sensor is blocked - and reversing the door motor. If you try yhtis with the remote the door may not move at all or just bump down and stop.
You should re-align the sensors as described in the link below. Good luck!
How to Replace the Safety Sensor for Garage Door Opener Repair Guide Help...
How to Adjust Photo Eye on Garage Door
Nov 03, 2014 | Craftsman Professional 3/4 hp Hydro-Glass...
My garage door opens fine, just wont close with remotes. Lights just flash. I have to use the opener in garage and keep the button pressed in till the door is fully closed or it will reverse.
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
Jul 27, 2011 | liftmaster Garage Door 1/2 Hp
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP opener won't close
strange, was going to say eyes not aligned but you say they are. try over-riding by holding down wall pushbutton or jumping from red and white terminals. Did you increase down force. Are limit switch terminals moving, If it hits one, it should go back to other,
Feb 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
3/4hp craftsman will not close the door fully
There are adjustments on the unit itself that control the distance door travels to close as well as the force it uses to close. The info and location of controls is indicated in the manual that came with your unit.
Apr 12, 2017 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
839 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
