Question about Fujitsu Office Equipment & Supplies
I have a fujitsu FI-511oc I scan in the document into a folder I have made everything is there then I make a new folder scann in the documents everything looks ok then I get out of were I have scan the folders and the info that was scanned into the 2nd folder is in the first folder the weard part the same names of the 1st and 2nd doc's are the same and I was not asked to replace the first doc there are 2 doc's in the same folder with the same name
SOURCE: how to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
SOURCE: Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Posted on Mar 10, 2008
dragon_sun25
  • 107 Answers
SOURCE: Will the Fujitsu ScanSnap FI-4110EOX2 scanner work with Vista
Vista is not listed as a supported os.
Posted on Dec 10, 2008
  • 16 Answers
SOURCE: Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Posted on Sep 16, 2009
  • 3278 Answers
SOURCE: I have a Fujitsu fi-5110C
Hello, Jim.
The most common cause is from a particle of ink or dust that is attached to the lamp or the glass covering the lamp. As the page runs over the lamp, it registers that spot as black and causes a line to run the length of the page.
To fix this, simply remove the particle from the glass or lamp. The location of the particle will correspond to the location of the line on the page. So note which side of the page this occurs.
Here's an article from eHow regarding cleaning the scanner glass: http://www.ehow.com/how_14267_clean-scanner.html
Pay attention to that black particle.
Hope this helps.
Posted on Sep 07, 2010
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
After scanning several pages, I don't know how to save it as one file.
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Jan 17, 2013 | Fujitsu fi-6130z - Document scanner -...
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
How do i scan?
Dallis,
1. Please power on the scanner.
2. Place the document to be scanned in the scanner face down and close the lid.
3. Start the word processor.
4. In the File menu you will find an option to either scann a document or Import from scanner. Use this and start the Scan Document.
5. First you will get a rough scanned image. Set it right for everything to be scanned by using a dotted rectangle on the scanned image. Once that is done, then use the SCAN option and you will get the final scanned image.
6. Save it to a folder.
Feb 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu fi-4530C
Hi
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Scanning document
i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
i hope this was of some use
Apr 24, 2008 | Fujitsu fi-5120C
How do I scann a document/picture and where does it go once I scan
Usually any scanned document etc will go to a folder in documents & settings so have a look there, another way is to scan and save it as a special name, or simply remeber the default name, and then do a search for that file and when you find it, THATs where they go :)
Usually when ya scan it should ask ya where to save?
Feb 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
How to scanning double sided document in fujitsu 5120c scanner
Oct 23, 2007 | Fujitsu fi-5120C
73 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
