Question about Denon AVR-1700 Receiver
Denon avr-1700 icant get the tuner to change radio stations
    Problem Solver:
  • 9 Answers
If you have the owner manual check for reset and reset the unit. If you don?t have the manual unplug the power cable for a wile and then try again. Good Luck Toufic Malek
Posted on Sep 25, 2007
    New Friend:
I have this exact model. You have to use the factory remote. Open up the panel on the front of the remote, push the first set of up/down arrows to tune to a station. Press the memory button to store it as one of your presets. You press the preset button on the remote or the front of the unit to change to the station.
Posted on Jan 03, 2010
You may need the factory remote or a universal one that works for denon recievers.
Posted on Apr 01, 2008
SOURCE:
How do I Get all radio stations on my remote .
That depends on how your TV is set up for radio reception.
Some TVs have a dedicated FM/AM radio tuner. This requires signals from both forms of radio antenna.
More commonly now though, digital TV includes a wide range of radio stations broadcast as part of the TV range. In the UK, the radio stations are grouped in the 700+ channel range. e.g. 701 is BBC Radio 1.
Sep 09, 2014 | Televison & Video
Dewalt DSCN1360 tuner problem
Don't you have an automatic tuning system or ATS? By pressing a band switch for a while the ATS starts looking for stations and stores the ones that have a good enough signal. Even if a station broadcasts but the location of the radio is not adequate for a good signal to be received, the station won't register and it will appear to you that the tuner is skipping.
Dec 02, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
When changing radio channels the dx mode appears instead of lo (local) cant get a signal
dx is short for distant. this just makes the tuner more sensitive and should pick up more stations. if it is not picking up stations in dx mode, you either have a bad antenna or a bad tuner.
Mar 22, 2011 | Clarion DXZ545MP CD Player
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
How do you change stations on fisher da350 no buttons on the radio will change the radio station
Change to Tuner using the Funtion button. Continue to press the MEMORY button until it starts to scan the frequencies.
Jul 19, 2010 | Fisher DCS-DA350 Shelf System
Problem to find radio station on tuner?
FM ( at least in the USA) only goes 90.1-90.3-90.5 and so on.
This is how stations are separated.
There are no stations on 90.4 or 101.6 and so on
Nov 02, 2008 | Denon AVR-1803 Receiver
SI686
To activate the sound soother press the round button on the bottom left of the unit marked soother. To change the Soother stations press the "Tuner buttons either left or right. The tuner buttons are located on the bottom half of the unit above the volume buttons. one click of the tuner button moves one station on the sound soother selection.
Jul 06, 2008 | Sharper Image SI686 Clock Radio
Denon AVR-1700 Receiver Logo
1,462 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
