Question about RCA RD1076 MP3 Player
Cannot remore the preprogrammed songs
My player uses sd memory cards which i have separated by different type music (country, gospal, oldies etc.) but when listening to my music one of the preprogrammed songs that came with the player comes on and just ruins the listening pleasure for me. i want to remove these songs but the step by step in the owners manual does not do it for me. help!
    Problem Solver:
  • 10 Answers
1. Connect your Lyra to your computer with the proper cable.
2. Click and open "My Computer" on your desktop.
3. Click to open the drive that is labeled "Lyra".
4. Right-click on the offensive song.
5. Cloose "Delete" from the menu.
6. I hope that works.
-Potter4
Posted on Jan 24, 2008
SOURCE:
Why won't the RCA Pearl TH1101A MP3 Player read a mini sd card for external memory? Is it a format issue?
could it be that it requires a certain type of card . or smaller mb than you are trying to use
Feb 19, 2015 | RCA TH1101 MP3 Player
One month before I bought this Coby M828 MP4 player. Now I want upgrade my memory that why, I bought 8GB Micro SD card.I installed the card and transfer the music file all are OK. But I can not access my...
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing me to give my opinion about your situation. So what you are saying is that one month ago you bought a Coby MP828 MP4 player, but wanted to upgrade the memory, so you bought an 8GB Micro SD card. You can transfer music properly, but can't access files from the media player. Your memory device is shown but you can't create a playlist? Well Faizal, we need to first troubleshoot where the root of the problem is coming from, then find a way to solve it. I researched your device's technical specifications and have come up with some possible causes to the problem. The first possible cause could be the type of SD card you are using; the second possible cause is the type of file format you are using to save your files. I compared the Micro SD card and the Mini SD card and the differences between the two do not affect its compatability to the device, so it looks like you can use either one. You could obtain a mini SD card to see if that does the trick, but I don't think it'll make a difference. So it must be the type of file format you are using. The Coby MP828 MP4 player supports MP3, WAV, FLAC, ACC & WMA audio formats. If you are using something different than the formats shown above, that may be the reason why you can't upload your files. Another possible reason could be firmware or software. Your device doesn't offer any firmware updates, but you could try re-installing the Coby Media Manager software to see if that makes a difference. Since you wanted my opinion, I think the second possible cause (that being the file format) is why you can't make a playlist. I don't really know what else to offer you, but I hope this solution helps.
Sep 25, 2011 | Coby MP828 MP3 Player
I download music onto my 2GB memory card,i can't find it on the phone?My external memory says there is music on the phone.What do i do to listen to it.
What phone are you using? also in the media player onthe phone you should be able to search your sd card.
Mar 22, 2011 | LG Cell Phones
My card does not read both music and video what should i do
Are you using it with the same device? Some devices handle the formatting of the SD card differently. If so, devote one card for each MP3 player or camera, etc.
Mar 23, 2010 | PNY 2GB microSD Memory Card
Memory card
Have you formatted memory card in phone before you started storing data on it? By formatting the memory card it will set up folders which the phone will look at to determine different types of data, i.e. photo folder holds photos, video folder holds mp4 &3gp, and music folder holds mp3 etc.
Then when your memory card is connected to your pc drag and drop data into correct folders and then phone should be able to recognise the different types of data. Hope that helps?
Only other thing I can think is that your memory card is too large to be recognised by your phone? It will only support upto and including 2gb Micro SD cards.
Apr 24, 2009 | LG KU990 Viewty
MP3 wont play in my LGkeybo
I have a Keybo 2 phone so I assume the procedure is the same for the first generation Keybo.
1) First of all, only MP3 format works, period. Don't waste time trying to load WMA or any other music format.
2) Get a micro SD card as this opens up other features of the media functions
3) Using the USB cable, connect your phone to the computer and there should be 2 file browsers that will show up: one for the internal memory and the other for the external memory (micro SD).
4) On the external memory browsing window you should find a MY MUSIC folder. Copy all your MP3 music files into this folder.
5) Unplug the USB cable and open your phone's music player. It will detect the new songs and build update the library.
There you go, you're all set! It took me a couple of hours of searching and tryouts but this works every time. Good listening!
Jan 18, 2009 | LG 10X DVD IDE 452000078
Saving songs on sd memory card
try just sending music from your pc to the memory card
Mar 27, 2008 | Motorola Mobility i870 Cellular Phone
Using the extended memory feature via SD card
With my Joybee 130, the SD card appears as a separate drive when you plug the player in. In Media Player, I have to select the correct storage device and set up the transfer by playlist using Tools Options Device, then Sync the device. If you are using Explorer to copy files to your device, again, check to see if a second drive letter appears in the directory tree. Good luck
Dec 09, 2007 | Audio Players & Recorders
Saving music on my micro sd..
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
Nov 24, 2007 | HP iPAQ H1910 Pocket PC
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
RCA RD1076 MP3 Player Logo
110 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
