Question about Mantis Tiller
Mantis tiller stop working. I was tilling my garden and it completely stop. I try to sart the tiller but the puller cord wouls not move. Took the pull cord top from motor the pull cord assembly was working . The motor will not turn in any direction. Any suggestions?
  • 15 Answers
OOOPS...this sounds bad, like a locked up motor. If it is a 2 cycle engine it is especially bad...and it probably is toast. Take it to a shop and have someone check it out, but doesn't sound good..Sorry
Posted on Jun 03, 2009
Starting manual for mantis
all of the mantis tiller manuals can be found here:
http://mantis.com/mantis-owners-manuals.asp
just pick out the appropriate one and away you go.
as far as starting it goes, make sure the switch is set to "I" and not "O" (top handle.) be sure you have gas in it, pull out the choke knob (front of the tiller) and depress the bubble once. pull the engine cord until the machine tries to start, then push in the choke and pull again - the engine should start within a couple of pulls. let it warm up before you try to do any tilling, and you're good to go!
Sep 12, 2012 | Mantis Gas Mini Tillercultivator 2cycle...
I used my mantis electric tiller for the first time today and more times than I can count, it didn't grab into the earth and came racing back on me very quickly-the earth was pretty hard but I was...
a mantis tiller is low end. It does not have the weight to do any real tilling. Granted they are all gonna be hard to control, but unless you have, a bed that is soft soil , it will not work.
Mar 26, 2011 | Mantis Electric Mini Tiller/Cultivator
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
We purchased a mantis 2 cycle garden tiller new and have only used it 3 times. it has only been used maybe 1 hour total and now it wont start at all. what can we do to get it to start?
Empty mantis fuel tank. Remove and check spark plug. Replace with Champion CJ8Y or NGK BPM7Y if necessary. Gap is .6mm - .7mm or .024" - .028". Prepare fresh fuel/oil mixture. Add fresh fuel to tank along with 2 ounces of 100% acetone (available at walmart) - this will remove deposits inside of mantis from sitting for prolonged periods. Try to start several times. If unsuccessful let mantis sit for a while. Do this several times if necessary. Eventually it will try to start. If it will not remain started then you are successful in completing the previous section. Next you need to watch this video and do what it says. It is actually quite simple.
http://www.alamia.us/mantis_parts_s/148.htm
Feb 04, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Mantis tiller rpms shoot way high with slight increase in throttl
It is leaking air into the intake somewhere or
the rings are shot
the crank seal is shot
the crankcase gasket leaks.
Jun 08, 2010 | Mantis 2-Cycle Tiller
4 cycle engine luggs down when digging in the garden. It starts easily. What is causing it.
This is a small machine and tilling is very difficult work. What you are expxeriencing is probably as a result of very difficult soil.
May 15, 2010 | Mantis Tiller 4 Cycle Engine Handy Item...
Engine looses power, then speeds up, then looses power again
This sounds like the little fellow is getting hot. Are you using a good oil in the fuel don't skimp on that oil use the best you can find and get a new plug to sounds like the oil is killing your tiller.
Aug 02, 2009 | Mantis Tiller
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Mantis Tiller Logo
390 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
