Question about Logitech Computers & Internet
Why does my numLock have to be pressed down everytime I start up my pc?
    Novelist:
  • 153 Answers
Whether numlock is on or off when you boot is based on a setting in your bios. When you first start the computer you should get a prompt indicating what key or keys to press to enter 'setup'. Once you are in there, simply go through the options until you find the option for numlock and set it so it gives you the desired behavior.
Posted on Apr 22, 2009
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Tip
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
on May 20, 2010 | Computers & Internet
Keyboard numbers are jumbled
How do you turn numlock on and off on the Dell 2110 netbook?
Dell Latitude 2110 does not have a numpad so it doesn't have a NumLock button,
Mar 07, 2011 | Dell Latitude 2110 Laptop Computer (Intel...
Laptop IBM T43 some of the keys are not typing alphabets only getting numerics.M,K,O<P<I are some of these
Hi. You need to turn the number-lock (NumLock) off. There should be a button on the keyboard to do this. If you find the button, hold down shift and press the NumLock button. If not,click - Start > All Programs > Accessories > Accessibility > On-Screen Keyboard, and click the NumLock button. This should solve your problem. Post back results and good luck.
Feb 24, 2011 | IBM ThinkPad T41 Notebook
Hello, how can i turn off the numeric keypad. I am using Windows 98 and everytime I boot up, the letter that become the numpad, act as the numpad and a shortcut to open the browser... I don't know how this...
Hello, after booting OS WIN98 is NumLock set according setting in BIOS of the computer. Try to get into the BIOS (pressing a special key during boot - usually Esc, Del, ...) What key, it is often shown on screen at booting time (or in users guide to PC or its mainboard). Look into the BIOS, and do not change other settings - just set NumLock on start to OFF. Be careful - do not change settings which purpose you don't know / improper settings could cause PC not to start. If you are not sure, you have always possibility to leave the BIOS without changes - leave without saving. If you are sure, you have changed just the NumLock key status, select Save BIOS setting - of course.
Oct 19, 2017 | Solidtek KB-3910BU Keyboard
Numlock problem in HP DV9000
why need to press numlock when it has already a numeric numbers above? when pressing numlock on a laptop it will turn the letters to number because you lock the it. now to go back on the letters you have to press again the numlock key.
Apr 07, 2010 | Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
How do I set numlock to be on at start up?
Hi there
you need to restart the PC and enter the bios, this is usually F2 on start-up, have a look through the bios and set the numlock to on at start-up.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Toshiba Satellite P205-S7476 Notebook
Keyboard problem
yaa its nothing wrong. You have enabled your key for Numlock.
Hold Down Fn key (See bottom row, Left side of the keboard) and press Numlock key. Then your numlock will be off and Pressing K will type K.......etc.
Please don't forget to rate this solution........ofcource Fixya
Thanks for using fixya
Iqbal
Mar 31, 2008 | Acer Aspire 5670 Notebook
Computers & Internet Logo
99 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
