Question about OKI C3400n Laser Printer
Toner Sensor Error - Cyan. I got this error after
Toner Sensor Error - Cyan. I got this error after I replaced the toner when it said it was empty. Please help!
  • 4 Answers
If you have a lexmark disregard this because their printers wont reconigze most refilled ink cartriges even if its done by proffesionals such as wal-mart est. (warranty also does not cover refils you'd need to buy a new one) what you need to do is take it and get it checked to see if they put the coulor ink in right if they did, then gently wipe the sensor on the printer, and the brass part of the ink cartridge above the ink part, put it back in and see if that works. And lastly go to your printers driver and see if you can reset the toner levels from there manually, if you cant try turning off the sensors or tricking it (google various methods) or buying new cartridge
Posted on Apr 23, 2009
    Champion:
  • 214 Answers
I should be able to fix this in 24hrs
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
Jan 05, 2011 | Kyocera FS1120D Laser Printer
Toner Sensor Error for Cyan and Toner Out for Black
First, I wouldn't worry about the "K toner out", it might finally disappear once you get rid of the Cyan problem, if indeed you replaced the black toner for a new and healthy one.
Make sure that the cyan toner cartridge is securely fitted in it's drum unit, and the "knob" that opens the toner cartridge is in fully open position. Sometimes when manipulating inside the printer the "knob" might get moved a bit.
Generally, the toner cartridge sensor is connected via the drum unit, so usually the problem is with proper seating of the drum unit and good electrical contact between the metal fields on the sides of the drum unit and contacts protruding inside the printer. Cleaning both of any residue might help.
Once I had a defective toner cartridge, that caused such problem, but it was the contact between the toner cartridge and the drum that was broken. You have to experiment a bit.
I'm pretty sure in this model it is possible to swap two units - if you swap for example cyan with magenta, and observe if the error moves from cyan to magenta or not, you can draw conclusions if the problem is with the toner/drum, or with the printer not seeing the cartridge for some reason (sensor inputs killed by static electricity for example).
Oct 26, 2009 | Office Equipment & Supplies
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
Error code c0f30
SOLUTION: Check the amount of toner in the affected unit and if empty, check the alignment of the toner sensor actuator arm. It is possible that the arms may have been jarred out of alignment during shipment and fail to sense the low/empty toner condition. This in turn, causes the IU to drop below the proper toner-to-developer ratio resulting in C-0F3x codes. Once the actuator has been properly positioned, run ATDC toner supply until the T/D ratio comes back into the specified range.
hope that help
or try to reset the machine.........
Aug 06, 2008 | Minolta CF2001 Copier
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Toner sensor problems
sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
Dec 24, 2007 | OKI C3100 Led Printer
Nov 13, 2007 | OKI C9300 Led Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
OKI C3400n Laser Printer Logo
956 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
