Picture has white horizonal line accross it
A bright white line with black on the top and bottom of the white line. Scree went poof and Ican hear the sound but no picture. worth fixing?
  • dkahane Apr 22, 2009
    Note sure it it will fix the problem...What is "ic"?
  • dkahane Apr 23, 2009
    Yes, it answered my question will let you know if we deside to try to fix it. The line is across the screen not up and down? does that mean it is a horizontal intergarted circuit?
    Thank you.
  • 65 Answers
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Posted on Apr 22, 2009
  • Marcus Reid Apr 23, 2009
    ic is intergrated circuit. 90% chance that is your problem. By the way, don't play your tv with the vertical white line. Can damage the set.
    I'm sorry the wording is confusing. A horizontal white line is called a vertical collapse. You have a line going from left to right. This is the vertical IC gone bad or in need of resoldering.
LG DR4810 black and white lines at top left and side of Picture extending accross middle of picture window. How Do I remove these?
I think you should take it back, cause! defective laser pickup, or the video processor, and possibly the audio/video cable, "replace to be sure"
May 08, 2012 | LG DR-4810 DVD Recorder
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
White lines
These are retrace lines. This may be a fault in the blanking circuits. On some occasions a weak CRT can also cause blanking lines to show.
This is something you would not be able to service yourself. I would suggest to have an estimate done on the TV set for you to decide if it should be serviced or not.
Jerry G.
Apr 07, 2008 | Philips Magnavox 27MS343S 27" TV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
Electro Med Services...
