Question about Kyocera Mita FS-1920 Laser Printer
Call Service issue
Hi Printer is out of service (Display says Call service 4200:0105856) Model Kyocera FS-1920 I would really appreciate if you email me back with the answer to this problem. Regards Sunny
    Sniper:
  • 56 Answers
Hi sunny82 ,
I think You have defective laser unit,but first try to clean it.
Posted on Nov 02, 2007
SOURCE:
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Jun 22, 2012 | Kyocera Mita FS-1920 Laser Printer
Hi, just wanting to know how to clean an imaging unit on a Kyocera FS-1920
open 2 screws at the top cover remove the cover take a soft wipe comes with the unit or any soft clothe and wipe gentle
Jul 21, 2011 | Kyocera Mita FS-1920 Laser Printer
I need to purchase a power supply for a Kyocera FS-1920 network printer
call a kyocera dealer or do a google search... google search will always be cheaper...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Nov 17, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
251 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
