Question about Microsoft Ninja Gaiden® BLACK for Xbox
Where are all the scarabs
I only have 45 scarabs where are they, all 50
  • 659 Answers
- Golden Scarab 1 - Near Crew Compartment -
After defeating all the enemies in the Crew Compartment and going through the
now unlocked door, there is another door directly in front of you. Go on
through and you'll find a Map of Tairon and your first Golden Scarab sitting on
a windowsill.
- Golden Scarab 2 - Living Quarters -
Now that you have the ID Card, head all the way back to where you started and
go through the door that was locked. Here, climb up the boxes on your left,
then to your right. Finally, climb up the last set of boxes to your right. Now,
look around up here until you see a stack of two boxes between all the other
boxes. Jump over to here and grab all the items in the chests and in the small
area without a box. Down here is another Scarab.
- Golden Scarab 3 - Gas Compartment Passageway -
Kill the five soldiers in the first part of the Gas Compartment Passageway.
After you kill the last three, look for the large metal box on the left side of
the upper area. Run up it. Now, wall run up this wall and jump off of it. You
should end up on a catwalk. Up here is a Scarab.
<CHAPTER 4>
- Golden Scarab 4 - Great Bridge Square -
Unlock and go through the five green gem door near Muramasa's shop in Clock
Tower Plaza. Almost immediately to your left is a small fountain with a Golden
Scarab in it. So, go grab it!
- Golden Scarab 5 - Clock Tower Plaza -
After you find the dead body of the ninja Suke, the Scarab will be right in
front of you.
- Golden Scarab 6 - Near Han's Bar -
Once you discover you need a ticket to get into Han's Bar, turn around and a
Kunai will fly down near an alleyway. Run down said alley and grab the Scarab
at the end.
<CHAPTER 5>
- Golden Scarab 7 - Above Moat Road -
After you get the Pegasus Key, turn around and you'll see a Scarab. Wall run on
the right wall, then the back wall and land in the small nook. Grab the Scarab
here.
- Golden Scarab 8 - Drawbridge Hill -
Cross the Drawbridge and climb up the stairs. After you kill the three Black
Spider ninjas at the top, head to the save point and turn right. Bingo!
- Golden Scarab 9 - Drawbridge Hill -
Facing the save point, turn right and run down here and down the stairs. At the
bottom of the second stairs, turn left and grab the Scarab in the crevice here.
<CHAPTER 6>
- Golden Scarab 10 - Monastery; Archives -
After clearing out the Archives for the first time, run up to the second floor
and break open all the glass cases. A Scarab is located in one of them.
- Golden Scarab 11 - Monastery; Archives -
After grabbing the tenth Scarab, continue through the Archives and you'll find
this Scarab on the third floor, where you land from the Flying Bird Flip to get
up there.
- Golden Scarab 12 - Altar Hall -
Leave the Archives via the third floor and you'll come out on a walkway. Run
around to the other side and jump over to the area behind the fence. Grab the
Scarab here, then wall run back up to the walkway.
- Golden Scarab 13 - Underground Cemetery -
Put the Book of Eons you got from the Monk's safe back on the altar and drop
down. It is directly in front of you.
- Golden Scarab 14 - Between Econtra Babel Specus and Giant Fossil Area -
After defeating the six Brown Imps in Econtra Babel Specus, go through the gate
and kill all of the Cyclops Wasps. Now, from the exit on the lower floor, turn
around and follow the wall to your right. When you reach a dead end, wall run
up the left wall. You'll end up in a small area with the Scarab.
- Golden Scarab 15 - Near Tomb of the Eons -
Drop down to the bottom of Econtra Babel Specus (not from the top! From the
second save point) and kill the enemies here. Head into the tunnel and on your
right is the Scarab hiding in a small niche.
<CHAPTER 7>
- Golden Scarab 16 - Coffin Chamber -
At the bottom of Econtra Babel Specus, where the Bone Dragon's remains landed.
Check around the room and you'll find the Scarab in a small crevice.
- Golden Scarab 17 - Suspension Bridge Room -
Right when you enter the Suspension Bridge room, turn right and grab the
Scarab.
- Golden Scarab 18 - Suspension Bridge Room; Chamber of the Blue Eye -
In the Chamber of the Blue Eye, drop down to the bottom and run to where the
Ghul Archers are. Underneath that ledge behind the pillar is a Scarab.
- Golden Scarab 19 - Underground Cemetery; Junction Chamber -
After the underground floods, you'll end up in an area with an elevator. Look
around a bit and you'll spot a Scarab lying underwater.
<CHAPTER 8>
- Golden Scarab 20 - Near Military Gate; past Skull Door -
Remember that Scarab back in Chapter 4 you passed but you couldn't get to it
because of a door with a skull on it? Go there and open up the door, and grab
that Scarab!
- Golden Scarab 21 - Near Military Gate; past Skull Door -
From the 20th Scarab, wall run up the wall behind the chest and jump to the
first ledge. Repeat that, and turn left. See the Scarab? Wall run over to it.
Carefully, though; this is a somewhat difficult jump to the wall.
<CHAPTER 9>
- Golden Scarab 22 - Military Supply Base; near Warehouse -
As soon as you come out into the large open area past the tunnel, turn left and
grab the Scarab that is sitting in the corner.
- Golden Scarab 23 - Military Supply Base; Warehouse -
You probably noticed this one when you jumped from the first metal plate onto
the train car. Jump over to the second train car, then get a running start and
jump for the car with the Scarab on it. Before you land, hit X with the Dragon
Sword to air yourself and get a little farther. Grab the Scarab, then jump back
the same way.
- Golden Scarab 24 - Military Supply Base; Warehouse -
After you grab the Shutter Control Card Key and the Map of the Military Base,
leave the room and turn around. Wall run up and grab the Scarab hiding up here.
- Golden Scarab 25 - Military Supply Base; near Rooftop -
Run down the bridge after you destroy the helicopter and head to the pipes
blocked by chains. Wall jump between the two and grab this Scarab at the top.
Posted on Apr 22, 2009
  • Wesley Gardner
    Wesley Gardner Apr 22, 2009
    - Golden Scarab 26 - Key of the Insect Room -
    After killing the Thunderbolt Worm, run through the archway and turn around.
    Wall run up the wall and grab the Scarab up here.
    - Golden Scarab 27 - Hall of Balance -
    From Scarab 26, continue down the hall and you'll reach the Hall of Balance.
    There is a Golden Scarab up here, on the other side of the catwalk.
    - Golden Scarab 28 - Red Water Reservoir -
    To the right of where you place the Red Tablet of the Stream is the Scarab.
    - Golden Scarab 29 - Underground Waterway -
    After landing in the Underground Waterway, run forward a bit and look left. The
    Scarab is sitting behind the wall.
    - Golden Scarab 30 - Underground Waterway -
    Kill the two Thunderbolt Worms, then get the Scarab from the left tunnel.
    - Golden Scarab 31 - Blue Water Reservoir -
    At the bottom of the reservoir.
    - Golden Scarab 32 - Peristyle Passage -
    Look at the tops of the pillars and find the one that doesn't reach the
    ceiling. Wall jump to the top of the pillar and grab the Scarab up here.
    - Golden Scarab 33 - Underground Sanctuary -
    There is a small room on the left if you enter here from the Peristyle Passage
    entrance. Go inside and turn left when you enter. There! Grab it.
    - Golden Scarab 34 - Underground Sanctuary; 2nd floor -
    After you grab the Brand of Valor, check behind the pillar where the save point
    is. Grab the Scarab here.
    - Golden Scarab 35 - Moat of Zarkhan; near Underground Sanctuary Door -
    When you dive into the water, turn right and you should see the Scarab sitting
    underneath the broken fence.
    - Golden Scarab 36 - Moat of Zarkhan; near Imperial Palace of Zarkhan -
    Check your map and make sure the red arrow is near the "Imperial Palace of
    Zarkhan". This one is located on a ledge above the tunnel leading to the Island
    in the Moat. Grab it after killing the three Laser Helis.
    - Golden Scarab 37 - Moat of Zarkhan; Past Island in the Moat -
    As soon as you emerge from this tunnel, turn right and swim down a little. The
    Scarab is sitting in the corner.
    - Golden Scarab 38 - Moat of Zarkhan; Sunken Ship -
    After operating the hand crank, swim back inside the ship and up into the new
    area you opened up. At the back of this area is a Scarab and a Oxygen Tank
    (breathe underwater forever...grab it!).
    - Golden Scarab 39 - Flooded Underground; Chamber of Eternal Sleep -
    Swim ALL the way up to the top of this room and grab the Scarab that is stuck
    on the wall. It's above the coffin.
    - Golden Scarab 40 - Zarkhan Stadium -
    Grab the Kitetsu and run forward into the area where Doku came from. Behind one
    of the pillars on the left is a Scarab.
    - Golden Scarab 41 - Zarkhan Stadium -
    Once you move all of the stone platforms into place, you can get this one. It
    is lying on top of the archway that you came in from (the elevator).
    - Golden Scarab 42 - Zarkhan Stadium -
    Get to the top of the Stadium, then run along the ledge with the switch until
    the end. There is a Golden Scarab sitting up here.
    - Golden Scarab 43 - Near Zarkhan Falls -
    Break open the right stone head near the save point and grab the item inside.
    - Golden Scarab 44 - At the bottom of the pond by Zarkhan Falls -
    Simply dive in and you should notice the Scarab glowing atop a rock.
    - Golden Scarab 45 - Magma Cavern; Ancient Iron Furnace -
    After melting the four Iron Ore pieces, turn around and walk off the edge.
    There is a small platform with a Scarab sitting on it, so grab it and leave the
    room.
    - Golden Scarab 46 - Ice Cavern; Near Ancient Iron Furnace -
    Grab the Cog of Vigoor, then save at the save point. Turn right and grab this
    Scarab.
    - Golden Scarab 47 - Magma Cavern; Path of Flame; Second Set of Flamethrowers -
    After the flamethrower on the right is starting to stop blowing fire, run to
    the left and grab the Scarab that is sitting here.
    No Scarabs in this Chapter.
    - Golden Scarab 48 - Zarkhan Labyrinth; Past the Lion Door -
    From the Lion Door, head left and grab the Scarab in this enclosed area at the
    end of the path.
    - Golden Scarab 49 - Zarkhan Labyrinth; Large Courtyard -
    As you continue to search for the Key of the Lioness, you'll come across a
    large courtyard (not the one by the Lioness Door). Sitting in the middle of
    this is a Scarab.
    - Golden Scarab 50 - Core of the Imperial Palace; Before Fourth Floor Room -
    Before entering this room, run off the edge on the right side of the door. Run
    along this ledge and grab the final Scarab at the end.
1986 Honda GL 1200 Aspencade Gold Wing will not go past 50 mph
Hi, George and the usual suspects are:
1. Dirty or clogged air filter.
2. Faulty spark plug.
3. Bad Gas.
4. Improper oil level.
5. Improper chain adjustment and lubrication.
6. Low tire pressure.
7. Dirty or contaminated carburetor needs cleaning and tuning.
8. Clogged or faulty fuel pump or injectors.
9. Improper valve adjustment.
10. Slipping clutch.
11. Improper timing.
12. Low compression.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
85 gl1200 will not go over 50 mph GL1200 Information Questions...
Goldwing Air Cutoff Valve Cause for Poor Performance
Honda GL1200D Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 Aspencade Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 28, 2018 | 1986 Honda GL 1200 Aspencade Gold Wing
6 letter word using these letters iefsrbmajac
briefs, camber, fabric, fascia, frames, camera, safari, racism, scream, fibers, braces, scream, crimes, scarab, carafe, rabies, braise
I'm sure there are many more, but these are a start.
Sep 06, 2014 | Computers & Internet
How to get a 1986 scarab wiring diagram
contact dealer or factory !
Sep 05, 2014 | Cars & Trucks
One helmet gor various activities
I see this has been here a while... But hopefully it can help. The only multisport helmet to hit the market recently is the Kong Scarab. We had a few in the shop here with mixed results.. It's rated for a bunch of sports though variously I got responses like "too heavy" "too hot" Too bulky" etc, depending on whether it was a climber, paddler, skater etc.. So I guess the answer is yes, it does exist, but it's not perfect...
Dec 01, 2008 | Black Diamond Diamond Tracer Climbing...
Microsoft Ninja Gaiden® BLACK for Xbox Logo
456 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
