Question about Philips 60PP9352 60" Rear Projection Television
Rear Projection/Convergance Problem
I turned on the TV this morning. It was on for about 30 minutes that I heard a sound and the colors immediately were off. It reset itself after about a minute, but then it did it again. I used the remote to try to correct the convergence, but the red won't move enough. I went to the multi red and the lines in the middle were OK, but on the left they were too far left, on the right, too far right. I tried turning off the tv and back on, but the problem is still there. Is this something that I may be able to fix, or am I going to have to pay to fix this?
  • JasonCarmony Sep 24, 2007
    Do you have any idea what the cost to repair this would be?
    Genius:
  • 1,153 Answers
If you can solder and know components and how they work, you can fix, but the convergence is a hard area to work on. So I would say if you have no or low experience then let tech. There are bad resistors on convergence board. Also maybe loose connection around converg. amps. Hope this helps!
Posted on Sep 23, 2007
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Looks like watching 3D movie(colors) and rounded
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Double Image
Dec 24, 2007 | Toshiba 55H70 55" Rear Projection...
TV turns on, No pictura at all, and a clicking like a signal light can be heard.
sounds like you have bad convergance amp ic.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 20, 2007 | Hitachi 46F500 46" Rear Projection...
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Aug 25, 2007 | Philips 60P8341 60" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
