Question about Ricoh Office Equipment & Supplies
Lanier LF225m low temp error, how reset this code?
No reset other than power off/on. If the message returns, then you have a blown lamp, or fuse in your fuser
Posted on Apr 27, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
226 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
