Question about Samsung Digimax A6 Digital Camera
Memory card how do i get the pictures from the memory card to pc?
Just connect the camera to PC with usb cabel or use some card reader. there will new removable disk icon appear in windows explorer (if using windows) or other file manager. Then just copy the  fotos to PC.
Posted on Oct 21, 2007
SOURCE:
I have an LG Cosmos Touch that I took pictures with, and now I want to send the pictures to my PC so that I can save them. How do I do that. I did not receive a software disc when I got the phone.
If the PC has bluetooth, switch it on and send the picture through bluetooth to your PC.
Or save the picture on the SD memory card, remove the memory card from your phone and get a memory card reader that will help you to connect the PC with the SD memory card. After connecting, you can now send the picture from your memory card to your PC directly.
Just go to my compute, open the SD memory card right on the picture and send to your PC.
Regards
Jul 05, 2011 | Cell Phones
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
There are pictures on the sim card that only appear when I import them onto my computer but arent there when I look threw my other pictures on the camera. How do i delete them off the sim card? Please...
Deleting files like pictures or videos in camera memory card usually can be done via the camera itself or via PC. As long as your PC can read the pictures, you don't have to delete them via camera, but you can delete them via PC.
If you don't want those "ghost" picture stay still in your camera memory, you can select all and copy or cut all of your pictures to your PC (to make sure that there are no more pictures in your camera memory). You can format the memory card to make it new again (or not, its up to you), then you can copy back only your wanted pictures into the camera memory and leave the "unwanted" pictures in your PC.
This method can also reduce used memory in your camera.
Hope this help and be kind to rate this answer.
(^_^)
Jan 06, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I upload photos from my computer to the picture frame? The frame says PC Connection established. Remote is temporarily inoperative.
does the picture frame have an internal memory or accepts a memory card?
if memory card is accepted then try uploading images to the memory card and then inserting the memory card into the picture frame.
i hope this was helpful.
Dec 12, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
Sep 05, 2010 | Kodak Easyshare M580 Digital Camera
Can not download pictures to pc
Hi...
There is another osption to download you picture to your PC. Try to use a memory card reader, get your memory card in your camera. Inert it into the memory card reader and plaug your card reader to your computer. Now, you can download your picture to your computer.
Regards
PCmania
Sep 02, 2009 | Sanyo Xacti VPC-T700 Digital Camera
How do i transfer the pics on the cam to the storage card? Sony Cybershot DSC-S780 I do not have the manual for instructions
One way is to plug it in to a pc or laptop without the memory card the save the pictures on the pc. After put the memory card in the camera and move the pictures in the camera again so it goes in the memory card. All pictures you take with the memory card automatically go in the memory card.
Jul 15, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Uploading pictures on PC
This one is easy. Buy a memory card reader and do not use the camera usb cord. A card reader will always be the easiest way to transfer photos from memory stick to PC.
Nov 12, 2008 | Cameras
Memory card formatted in error
Once the memory card is formatted, the files saved or pictures will be deleted and there is no way to retrieve the images.
I would advise that you transfer the pictures first to your PC before formatting the memory card.
Sep 25, 2007 | Cameras
Samsung Digimax A6 Digital Camera Logo
62 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
