Question about Generation 2 Worldwide Geneva Crib
Need screws and one squeeze trigger for side of crib
I need to get the screws to put the mattress spings on and one of the squeeze triggers to put the side of the crib down
You should check on product america.com. I am not positive that they will have exactly what you need but when I was looking for parts for our crib that was the one place I found most things. Good Luck
Posted on Apr 22, 2009
I.need.instructions for the afg baby furniture.009e expresso athena naomi convertible crib 009
Tips a safety crib must have:
  • No missing, loose, broken, or improperly-installed screws, brackets, or other hardware on the crib or the mattress support.
  • No much more than 2 3/8 inches between crib slats so a baby's physique cannot fit via the slats.
  • A firm, snug-fitting mattress so a infant cannot get trapped between the mattress and also the side of the crib.
  • No corner posts more than 1/16 of an inch above the finish panels (unless they are more than 16 inches high for a canopy) so a baby can't catch clothing and strangle.
  • No cutout areas on the headboard or foot board so a baby's head cannot get trapped.
  • A mattress assistance that doesn't effortlessly pull apart from the corner posts so a infant can't get trapped in between mattress and crib.
  • No cracked or peeling paint to stop lead poisoning.
  • No splinters or rough edges.
Jan 20, 2014 | AFG Baby Furniture 009E Espresso Athena...
Lowering the mattress
I have the same issue... can anyone let us know if you have managed to put the mattress on the lowest (4th hole) setting? PLEASE.
Jul 28, 2010 | DaVinci Emily Crib
Cant put the crib togther
First you will need all of the original hardware that came with the crib for it to be safe. Then you might want to google it to make sure there were not any recalls on it ever, just to be safe again.
Then I beleive you will need 2 flat screwdrivers and an adjustable wrench or plyers. You will need to connect all four sides and the bars that go under the sides that release the side to go down. Then the parts that hold the mattress and then the mattress.
ETRONIC
Mar 15, 2010 | Bassett Mission Crib
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
Keyless chuck is locked; won't turn
you will need to replace the chuck.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Oct 01, 2009 | Drills
Change the chuck on a makita DA39DA coredlesss right angle drill
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
I need to know how to convert it to a toddler bed
There should have been an extra board with the crib.
My sister-in-law swears her's didn't come with it, but our's did.
You have to remove the sliding front side, along with the metal rails that hold the rail. You''ll see a hole on each end. 2 long screws hold the board on.
Sep 18, 2007 | Delta Enterprise Capri 3-in-1 Crib
Generation 2 Worldwide Geneva Crib Logo
238 people viewed this question
Top Generation Baby Gear Experts
Dorel UK
Dorel UK
Are you a Generation Baby Gear Expert? Answer questions, earn points and help others
