Question about RTO Pit Bikes
I have a pit bike 125 its not starting wot so ever got good spark but still not start
    Scholar:
  • 192 Answers
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Posted on Apr 22, 2009
My pit bike 125cc and it has a spark and just wont fire up any ideas?
Posted on Apr 13, 2010
The coil on my 125 cc pit bike broke every time that I started the bike, I run the bike for a little while then go off killin the coil, I have tested two coil and both broke
Hi, Jose and the usual suspects are:
1. Wrong coil for service application.
2. Damaged or worn out spark plugs.
3. Spark plug gap too wide.
4. Damaged, leaking, worn out spark plug wires, boots, or center cap connectors check for spark leakage in the dark.
5. Excessive vibration due to the loose mounting bracket.
6. Faulty ground check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bad Stator Fix Don buy new stator for your engine Create battery op...
ELECTRONIC IGNITION
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
http://www.miniriders.com/tech-talk/29110-pit-bike-repair-parts-manuals-exploded-views.html
http://mypitbike.ru/downloads/SSROwnersManual.pdf
Dec 03, 2016 | Pit Bike 125cc 4 Stroke Dirt Bike
Stomp 125 will not start
Hi, Jack the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
stomp 125 clutch wont engage new clutch all think Pit Bike Club
Clutch Adjusting
Pit bike Direct User Manuals
http://www.wpbracing.co.uk/engine-parts
Oct 09, 2017 | Pit Bike 125cc 4 Stroke Dirt Bike
There is no spark it is a 125 pit bike just bort a new cdi ther plenty compresion but no spark can you help
there are 2 things you can do
1. check the plug/coil connection
2. make all the coil wires are hooked up properly
3. buy a new coil
Mar 24, 2011 | Pit Cycling
I have 125 pit bike and I'm might not be getting a spark changed the plug but still did not start. I think I have no spark.
Sorry to be harsh but you NEED to check if you have a spark before we go further, simply take the distributor cap off the spark plug and find a socket to fit the plug... then take out the plug and put the plug back in the distributor cap.. then hold with pliers (rubber handles so you don't get a boot from it) and hold it against a clean part of the frame. Now try starting your bike and you will soon know if your getting a spark or not, alternatively get a tester screw-driver and clip the clip on a earth and put the screw-driver into the distributor cap (saves taking out spark plug) and if it lights up then you have one. This may mean you need a mate if the bike aint electric start as you will need someone to kick it as you check for a spark... Hope this helps
Oct 25, 2010 | 2008 Tomos Se 125 F
RTO Pit Bikes Logo
1,235 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
