Question about Dishwashers
Dishwasher seems to be clogged, wont drain
My frigidaire dishwasher wont drain. model # fdbb204ofc1
    Problem Solver:
I had the same problem and it was solve by checking the food disposal were the dish washer is usually attached for draining, if you resently replaced the disposal it could be that the drain hold was never openned. I hope this helps
Posted on Apr 22, 2009
Frigidair dishwasher model fphd2491kfo wont drain does every thing else
Good Afternoon Tyler, thank you for your question! Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then there is a possibility that the drain motor may need replacing after a proper diagnosis from an expert. You can locate a certified technician directly through the manufacturer website or in your local directory.
Aug 28, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
My Frigidaire dishwasher will not drain. What is the knockout plug?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Feb 20, 2011 | Frigidaire 24 in. GLD2150RCC Built-in...
My frigidaire ultra quiet will not drain
Hi
Daniel
Nov 27, 2010 | Frigidaire Dishwashers
Wont drain water \
Several problems could cause this; 1. kinked or clogged drain hose. 2. Food or foreign object(such as bone is blocking the drain housing). 3. Defective pump. 4. Defective drain valves on some models. 5. Hose was installed on a new disposal and the drain connecting plug was not removed from the disposal before the hose was installed? 6. Some models use reversible motors in which the motor spun the pump Clock-Wise to wash and would stop and restart Counter-Clock-Wise to drain. But I think yours uses a drain valve, which could be clogged or defective. 7. Outside chance but a timer(control) could be defective. More that likely it is a clog or blockage.
Aug 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher not draining water. Not 100% sure on exact model, can't find any number or ID marks. Definitely Frigidaire though.
the model number is or should be located on the right side of the.cabinet where the door opens.any how the problem could be a clog in the drain hose. you can remove the hose from the side of the garbage disposal.use a shop vac and try and drain the water that way if it does not drain then you could have a grease clog if there is grease clogging it use a blow dryer to heat the hose up and this should remove
the clog.if the water does come aut the you may have a bad drain pump and or a control board.
Jan 24, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Water not draining
You need to access to the drain hose, located under the bottom panel, and check that this is not clogged, if you do not find anything in there, check that the connection to the drain line outside the machine is not clogged.
If still no luck, then check that the drain pump is not faulty, that is possible.
You can find schematics and replacement parts by entering model number here.
Feb 18, 2009 | Frigidaire Dishwashers
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
DISHWASHER WONT DRAIN
Have you checked the drain hose??? It may be clogged to some degree or where it meets either the garbage disposal or t-tailpiece, whichever you have, or where it comes out of the water pump. Also, the impeller inside the water pump might look good but may be worn, and check for broken glass which is hard to see in the bottom drain area at the grate. Hope this helps.
Jan 28, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
350 people viewed this question
Top Dishwashers Experts
Owen Barnes
