Question about Brother HL-2040 Laser Printer
Glow lite on; replaced drum and toner; printer is on and printing
Printer does not printer out any data; give command to print; does that; all that comes out is a blank sheet of paper; every since the drum and the toner were replaced; the printer has not printed any data
How to reset the toner light to replace the new one
Posted on Apr 29, 2009
I have a problem of when printing out that is only white paper that take it out even I changed new toner and no change . Pls u have any solution give me the solution .
For a laser printer, printing is a few steps:
* receiving the print-data (which seems to be working fine)
* putting an electrostatic charge on the drum, by using a laser to draw the print-image onto the drum (working?)
* forcing toner into contact with the drum, but only the "charged" part of the drum holds the ink (working?)
* using heat from the fuser-unit to "melt" the toner into the paper (working?)
* ejecting the paper
If the paper is warm, then the fuser is working.
If not, then your fuser needs replacing.
Either take the printer to a qualified printer technician, for professional trouble-shooting, or buy a replacement printer, and responsibly recycle the old printer.
Jul 07, 2010 | Office Equipment & Supplies
Toner light on, replaced toner cartridge, won't print, toner light still on, replaced with new cartridge, toner light still on and won't print.
unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Oct 30, 2008 | Brother Office Equipment & Supplies
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Changed toner cartridge and started printing. It printed about 5 pages and the rest blank. Brother HL 2010 Laser prineter
1.open the lid from back of your printer, you may see astiff film .,give a print command and check the film rolling visually , if itsbroken then it might give you annoying sound like something's broken , but itcan only be visualized giving a print command ,
if its really broken from edges it may give you this problem, it can be fixedby local service center , 2.(clean your printer ) >Open printer >remove the toner > check for any piece of stapler pins or any paper or anyother waste that's stuck in between drums. > if you have a wind blower machine blower it . > must keep in mind to blower it in open area, causeblack particalls will make you cough, or would get dusty, 3. your toner must have ink dust at one side, shake thetoner and then insert in printer , this will help you . I hope it helps you
Feb 08, 2010 | Brother HL-2040 Laser Printer
Is my 2550L toast????.
The HP 2550 does take a while to print. It calibrates through all the cartridges & then you'll see your print soon after. You probably need your printer professionally cleaned out with a toner vacuum, the squeaking could be coming from the drum or a pick up roller.
Jul 02, 2009 | HP LaserJet 2550L Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
180 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
