Question about Garden
Do not have book for pressure washer 330'' pleasr help me find a source,i am a widow and can not find istruction to use the power washer T hank you Name of product,Karcher,model number is ''330''
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
  • 313 Answers
SOURCE: Water is pouring out of
seal or oring problem.see www.pressureparts.com for parts etc
Posted on Jul 08, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
Clear hose not sucking up detergent
Check the manual. Bleach eats most plastics and rubber rings. If not flushed well after, the suction will be destroyed.
Jul 30, 2014 | Karcher 330 Pressure Washers
I have a husky 2200 pressure washer. What do I set gap on spark plug. (Lost insturctions)
20 thousands or about the width of two match book covers stacked.. there not that fussy, good to be close though
Jun 06, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
I have a gpw-3000 petrol power washer. the metal plate which is held on with 3 bolts which is on the intake side where the water goes in has cracked due to frost in a garage. where can i get a replacement...
http://www.dultmeier.com/catalog/0.901
http://www.pressurewashersupplies.com/pressure_washer_parts.htm
http://www.google.com/search?source=ig&hl=en&rlz=&q=honda+pressure+washer+parts&aq=1&aqi=g10&aql=&oq=honda+pressure+
Hope this helps!
May 09, 2011 | Honda Pressure Washer PSI 3000
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
What Spark Plug do I use for my Blue Max 2200 Power Washer.
Spark plugs: BPR6ES (NGK), W20EPR-U (DENSO). You cna cross ref any other equivalent with a spark plug cross ref book.
Thanks for choosing Fixya.
Kelly
Aug 12, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Re - karcher 330
Overload contition in circuit. Turn some stuff OFF.
Jul 21, 2009 | Karcher K2.26 Electric Power Washer
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
