Question about SDI iHomeaudio IH85B Docking Station, Speaker System
Connection problem, hitting bumps messes up the connection
I have the iH85B ihome cycler speaker and it keeps coming loose. Everytime I hit a bump, the connection gets bad and either is scratchy or will not play anymore. Do you have any suggestions?
  • hed1117 May 05, 2009
    Actually, mine has a loose connection between the ipod and the connector plate. My unit had worked flawlessly for about a year, both on my bike and as an over-the-shoulder accompaniment on long (2-3+ hours) walks. Then it worked sporadically for a week and now it will turn itself off within a few seconds. I wish i knew how to open up the sealed portion as I'm pretty sure it's just a loose connection.
I had the same problem when hitting bumps. I found that it was the batteries were moving to much when I would hit a bump and the Ihome would shut off and then back on making it sound like it was skipping. I put 2 small plastic pieces on the negative side of the batteries by the spring connector so that the batteries wouldn't move and that seemed to fix all of my problems.
Posted on Jun 06, 2010
Have a 2007 Dodge Dakota keeps stalling when hit bumps and turn
Only 2 thoughts come to mind having had vehicle with similar issue. 1) Iffy electrical connection to fuel pump that jostles loose on bumps and turns. Or 2) worse, a pinhole leak in the fuel line that unless jostled away from frame or other point of friction that made the pinhole runs fine but when contact lost from "plug" it sucks air and air hits carb/injectors. A Chiltons/Haynes repair manual may well give some answers other than what I have to offer.
May 02, 2017 | Dodge Cars & Trucks
Jvc am fm 200w model kd-sc500
By any chance , did you check all the speaker wires,
, could just be a loose wire at stereo or at speaker.
Jul 01, 2014 | JVC AM FM CD DET FACE CAR STEREO
My 2003 grand am gt , has monsoon stereo , the stereo seems to be working fine , but there is no sound coming from the speakers , ive put new transmisson in it two years ago and ever sence that the stereo...
If bumps affect the noise then you should be looking at loose wires and connections for the speakers and at the back of the system. Look for a bad earth or the earth wire connected up to something that is not really a good earth
Jan 12, 2014 | 2003 Pontiac Grand Am
Loud bang when I hit a bump with my foot on the break. No sound at all if I hit a bump without my foot on the brake. What is this?
indicates that lower suspension rubbers are broken and should be inspected by an accredited front suspension professional service center
Aug 09, 2017 | 2005 Nissan Murano
1994 Cadillac AC Blows through Main Vents hit a bump and it blows through defrosters, hit another bump, and it blows back through the main outlets>
Sounds like a faulty blend door actuator. This part diverts air from the different ports ie floor, vents, defrost. If it keeps changing when you hit a bump, either the actuator has a loose connection or it's bad all together.
Jun 09, 2011 | Cadillac DeVille Cars & Trucks
My radio trips and turns off everytime i hit a bump. can i install something to make this stop?
More then likely, you have a loose wire in the harness. Pull it out and examine it. Find out which wire is loose.
Mar 05, 2011 | Car Audio & Video
Why does the brake light keep coming on when hit a bump
your brake light is probably coming on because the fluid is to low in the resevoir. ther is a sensor in the brake fluid resevoir that is on a float. if the fluid gets to low the sensor tells thebrake light to come on . so if the fluid is just high enough to keep the light off, everytime you hit a bump the fluid sloshes around causing the float to drop and the sensor to turn the brake light on. also when your brake fluid level is low it tells you that you will either need new brakes soon or you might have a leak.
Dec 08, 2010 | 2000 Chevrolet Malibu
Everytime i hit a small bump or something the a/c makes a screeching noise, but this is only when the a/c is running, what's causing it to do that?
Your A/C Compressor bracket or bolts that hold it to the engine could be loose from vibration, so everytime yoiu hit a bump the Compressor moves around causing the A/C drive belt to be out of alignment, which is why you are getting a screeching sound. Check all nuts and bolts for looseness and re-tighten to specs.
Jun 24, 2010 | 2003 Pontiac Grand Am
My subs cut out everytime I hit a bump.
I would say the wiring, in particular the earthing for it, also check any "Compression" fixtures.and check ALL joints etc. To be sure give the actual Amp a gentle tap, and see if that brings on the fault.
Feb 21, 2010 | Rockford Fosgate Punch 401S Car Audio...
Blower fan goes off with hitting a bump
Check to see if any of the wire connections are loose.
Neil
Mar 14, 2009 | 2004 Pontiac Grand Prix
SDI iHomeaudio IH85B  Docking Station, Speaker System Logo
113 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
