Question about Toshiba TP55G60 55" Rear Projection Television
Power light is lit, but there is no power to the set.
In the midst of turning channels the set went dark, the power button is on and I cannot turn the set off or on. I have tried unplugging it several times and nothing happens. I checked all of the connections and nothing is out of place. What can I do?
    Problem Solver:
  • 5 Answers
Please define the brand and type of tv that you have...
Posted on Apr 22, 2009
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
Jan 24, 2011 | Televison & Video
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Sony KP61V75
How old is this set please?
Jan 03, 2008 | Televison & Video
Looking for programing codes
Turn TV on. Press and hold [Code Search] until LED stays lit. Repeatedly press [CH +] until the channel changes. Press [Enter] to save code.
Dec 13, 2007 | Universal Remote Control Remote Control
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
RCA 27F520T no picture problem
 Examine PCB closely,probable cracked board.Depending on
how severe,it may be fixable.Ask repairman what the bench labor
charge will be to repair,if repairable at all.
Oct 11, 2007 | RCA TruFlat 27F520T 27" TV
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
Televison & Video Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
