Question about Bosch Nexxt 500 Dryer
Hot air not blowing out vent.
Have a Bosch Nexxt 500 series electric dryer. Been working great then it just stopped blowing hot air out the vent. Need to know how to take front panel off of dryer to check to see if any clothing feel into vent inside dryer (I have kids). Also like to clean inside of dryer of lint build up. Will remove from vent to check dryer output, but it just stopped pumping out hot air, so that is why I am suppecting something inside just plugged up. Thanks!!
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 3 Answers
SOURCE: Bosch Nexxt 800 series dryer E01 error
If you are using dryer sheets...stop. They clog your linter filter. Use windex to clean the filter and a soft bristle brush....also check to ensure your dryer vent is clear using a shop vac to clean or a vent brush.
Posted on Dec 01, 2009
  • 3 Answers
SOURCE: Bosch Nexxt 500 series gas dryer lint building up inside dryer
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Nexxt 500 series dryer. Today I was
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
Posted on Dec 21, 2010
My Bosch Nexxt 500 dryer is TOO HOT.
You need to take care of this right away. Too many houses catch fire from lack of maintenance on dryers. Pull it away from the wall and unplug it. Check the inside of the duct work and clean it out. Then check the inside of the drier connection too. Run it without the duct connected and see if you have good air flow.
Jun 16, 2013 | Bosch Nexxt 500 Dryer
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a bosch 500 that continually heats even in air only option...to the point where the reset needs to be pressed....any help ideas?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
What do I purchase to connect my new dryer to the vent?
SHOULD JUST NEED A 4 INCH VENT HOSE AND TWO 4 INCH HOSE CLAMPS NORMALLY COMES AS A KIT... I WOULD RECOMMEND METAL FLEX HOSE INSTEAD OF THE PLASTIC STYLE AS IT DOES GET HOT WHEN EXHAUSTING AIR....
Jan 12, 2011 | Bosch Nexxt WTMC8320US Electric Dryer
Bosch Nexxt 500 series dryer, E:01 and lint light flashing. nothing is stuck in the door.
Jun 26, 2010 | Bosch Nexxt 500 Dryer
My gas dryer is not getting hot i tried cleaning vent and lint trap
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Bosch Nexxt 500 Plus Dryer
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Vent
if it were electric I'd say it was ok, but for gas, the combustion products go out through the vent along with the humidity.
Dec 27, 2007 | Bosch Nexxt WTMC 6500 Gas Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
200 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
