Question about Sony Ericsson K800i Cellular Phone
Soney ericssion k810i keypad 1,3,6 not working and no.3 press display shows shutdown and putting charger shows indicator but not charging the battery sir please help me
  • 2 more comments
  • yoobrio Apr 24, 2009
    I have this keypad problem on my K800i where some keys do not do anything when pressed but give off a tone. The keys are 4, 7, *, #, and 9. Pressing key 9 brings up the shut down menu for the phone. The rest of the buttons work as they should. I replaced the keypad membrane with a new one and yet I get the same problem. I tried turning on key sound "tone" under settings just to try to see if 4, 7, *, #, and 9 are responding at all. When pressed, they all give off a tone, but nothing is dialed on the screen for that key. I'm wondering what the problem is if anyone can please help. I really love this K800
  • Vincent Caste?ares
    Vincent Caste?ares Mar 21, 2012
    base on my experience as a technician for 5 years.. its a hardware problem.. try replace keypad flex, if no luck, cpu is damaged...
  • yoga_sss
    yoga_sss Dec 18, 2012
    Hi there, i am using k850i, and my phone will automatically off when i put in my bag, or if there is any vibration or pressure when i typed. Can you recommend me the solution to fix this?
  • yoga_sss
    Hi there, i was hoping to get a solution on my sony erricsson k850i. My phone will automatically off when i press on the keypad. Smetimes, left in the bag, the phone will off too.
Soney ericssion k800i keypad 1,3,6 not working and no.8 press display shows shutdown and putting charger shows indicator but not charging the battery sir please help me plz
faraz_khan718@yahoo.com
Posted on Jan 16, 2011
Why wont my hp 4530s boot?
This indicates one of the following:
1. Dead Battery
2. Incompatible Charger
3. Incompatible battery
4. Static Charge Overload - Take out battery, unplug charger, hold power button for 30 seconds, put battery back in, plug in charger and press power.
LB
Jul 13, 2014 | HEWLETT-PACKARD Probook 4530S 156 I52410M
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Am using sony ericssion mobile model no. is w760a AT&T, from last two day am connecting charger, but its charging asusally, after i disconnect charger is showing battery empty..
Ifthe sell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 24, 2011 | AT&T Cell Phones
My Sony Ericsson K810i Mobile have a problem. It shows the charge indicator nearby 99 % and if i speak a cll it goes very low and says 'attention Battery Low' and if i leave the phone to standby it shows...
Hi, problem can be solved. When a phone battery indicates 99 % of battery life and runs down so quickly, it is caused by damaged battery.
When a battery cell is damaged, it will display charging full but itwill empty. You will need to replace the battery for a better battery performance.
When a new battery is been purchase, make sure it is charge it is charge up to 4 to 5 hours before use.
Oct 13, 2010 | Sony Ericsson Cell Phones
Sony phone battary not chanring!!!
u can charge ur phone by another charger,,,
hope ur problem will be fixed,,,,
Jan 14, 2010 | Sony Ericsson W700i Cellular Phone
My K810i phone doesnt turn on..
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
Nov 11, 2009 | Sony Ericsson K810i Blue Smartphone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Sony Ericsson K800i Cellular Phone Logo
1,232 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
