Question about GE WBSR3140DW Top Load Washer
Washer smells when spinning
The washer is about 5 years old and when it spinnes it smells really bad like the motor is overheating.Could that be something simple ordo I need a new washer .I don't want to pay $200 or $300 to get it fixed .The I might as well buy a new one .What do you think???
  • Anonymous May 06, 2008
    I have the exact same problem. It almost smells like fumes but almost has a cat urine smell to it but we don't have a cat and never have. Its a very foul odor and just started.
  • Anonymous May 21, 2008
    washer in spin cycle dos'nt turn transmission and motor starts smoking
  • 291 Answers
I would take the front panel off the washer and stick my head in there a stiff around and find out what the smell really is before makeing a decision on another one
Posted on Sep 23, 2007
I have a MAV3905AWW washer, it lost the spin cycle first. tested and found timer was not sending voltage to motor. Ran 2 cycles after this and got burnt electrical smell and motor overheats. I replaced...
I beleive that your washer needs a hub and seal kit. Please check parts sites. I did some research for you and this part seems to be unavailable on many sites that sell Maytag parts. When the seal is defective, it make the spin cycle very difficult for the transmission and motor and cause overheating . On the wash cycle however, this seal is not in the loop and the wash cycle is performing without overheating the motor. I am afraid that you will need a technician to do this job if you ever find the part.
Jan 23, 2018 | Maytag MAV3905A Top Load Washer
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a fisher paykel washer that is not drain/spinning properly and I noticed a burning/hot smell. Anything i can do? It is 5 yrs old.
ours did the same thing with the burning smell also. I found that the pump motor kept tripping out from overheating and would not empty the drum thus telling the computer not to spin. I took out the pump and found that the rotor inside the armature had surface rust all around it so i gave it a light sand to clear the rust and whalah...no more tripping out, the pump motor needs to be disassembled to get at the rotor.
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
My 5 year old LSQ9659LW washer pumps but no spin
You could have two problems here. One is a bad timer not giving the signal to spin and the other burning smell is usually a belt slipping on the drive shaft. Either way, it's time to have it checked out. If it it's a newer model without any belt the electric motor is heating up and this definetly needs to be checked out.
Sep 17, 2009 | Washing Machines
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Frontloader 417.39022890
Hi thanks for the question. I would look at the pump. remove bottom panel. pump on the right, remove hoses, clean out the pump. thanks the appliance doc
Oct 07, 2008 | Estate TAWS800JQ Top Load Washer
Kenmore washer won't spin
ok " sounds like motor belts need replaceing, that smell is the loose belt rubbing against the motor pully.
Jan 01, 2008 | Kenmore 12502 Top Load Washer
Washer wont spin
sounds like the motor or clutch unit could be the problem I would for sure call in the warrente shop to fix it as if its the motor thats expensive!! good luck
Apr 29, 2006 | LG WM-1832C Front Load Washer
GE WBSR3140DW Top Load Washer Logo
145 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
