Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My deck blades will run if I hold the electronic switch but once I let off they quit. Is there a relay that the switch engages?
  • 246 Answers
Hello tiny_viking:
From your Description it Sounds like the Switch is Bad and Requires Replacing.
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
Pull switch that engages blades doesn't do anything..
the switch or the relay is probably bad. maybe the clutch itself is bad. need to test to see what is bad. check the wires going to the connections and the fuse to be sure they are connected good.
Aug 20, 2016 | Garden
Looking for the location of the clutch safety switch on an older toro commercial 11-32
Anytime your engaging blades it pulls quite a bit of juice from the battery, so you need to be absolutely sure your battery is good.
Jul 26, 2014 | Toro Garden
My rx75 runs well but will not engage the deck is it electronic?
The mower deck is 100% manually controlled with the yellow control handle. The linkage may be out of adjustment a lot, especially if new belts are now broken in. When engaged, the blade drive belt should be quite taunt,but not like a banjo string. Adjustment is easy and can be found on the operators manual.
Jun 18, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The electric clutch on my cub cadet lt1045 does not stay running
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Jun 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
73 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
