Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
Slow heating and control panel clicking
Both electric ovens suddenly stopped heating up at their normal speed and now take up to 45 minutes to get to 300. The gas stove top works fine. This is now accompanied by an intermittent "click-click" coming from the control panel. Could this be a breaker or fuse problem? Anything else? All help is appreciated!
  • jdversaw Oct 04, 2007
    All fixed! My heating coil was bad - simple solution. Tested and changed it and now everything works great. It is a bit discouraging because the unit was only a year old. :-(
  • helpjoe Dec 22, 2007
    I have the same problem. Slow heating and a intermittent clicking sound.
I have a similar problem with my Frigidaire FAM156R1A Air conditioner. The unit is stuck on a temp setting and occasionally makes a beeping sound. Repair tech came out and told me the control panel was broken and that this is a common problem. I wrote more detail here: http://www.epinions.com/content_404700761732
Posted on Oct 04, 2007
Oven heats very slowly
15 minutes until the signal beeps? completely normal, BUT it will take up to 45 minutes for any oven to properly preheat COMPLETELY.
Mar 18, 2014 | Thermador C302U Electric Double Oven
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
The oven will only heat to about 240 degrees. It's very slow to preheat and doesn't seem to get above 240 degrees in about 45 minutes.
The most likely cause is the bake element. The floor of the oven is removable exposing the element (74008693) It will likely be visibly broken.
Jan 13, 2011 | Maytag MER5775Q Electric Kitchen Range
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
My HBL452 double oven is slow to heat both upper
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
Nov 26, 2009 | Washing Machines
Top Oven Stops Working
Sounds like a bad sensor for the oven here is the link to the repair manual to help you out
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Feb 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Jan 27, 2008 | GE JVM1650 1000 Watts Microwave Oven
Whirlpool oven
When I had a similar problem, the door wouldn't unlock even after unplugging, waiting 30 minutes, and plugging the oven back in. I finally had to manually unlock the oven by turning the lock latch motor myself.
Here's a good page that describes what the lock latch motor looks like and where it's located. Of course, there is 220V current running around inside there, so please unplug before removing the back access cover and put it back on before plugging the oven back in.
My symptoms:
  • Oven failed to complete auto-clean cycle.
  • Oven started beeping; control panel showed FSE 1
  • About a minute after plugging in, oven started beeping and displaying FSE 1 again
Once I unlocked the door manually and plugged back in, the oven started behaving normally.
Jan 01, 2008 | Whirlpool RF368 Electric Kitchen Range
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
236 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
