Question about Garmin eTrex Legend GPS Receiver
GPSr shuts off
I have three Garmin etrex Legends that I use in my sixth grade class. When we turn them on, everything works fine until they hook up with the satellites and then the screen goes blank except for a very thin vertical line. We then have to remove the batteries to turn them off.
  • smartin333 May 25, 2009
    I get same problem with mine! Thin vertical line & remove batt to shut off. All works good til then.
  • 3,866 Answers
Firmware needs to be upgraded on these units because the atellites are changing every so often so does the programming in these units, check to see if there is a firmware upgrade to fix these problems, the line in the middle of the screen is because it either hung during the process or the units lcd is going bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
Etrex Legend locks up, screen blank except vertical line
Is the unit being bumped during use? If not, sounds like a call to Garmin tech support is in the works. My thought is that it's something defective inside your unit.
Jun 21, 2009 | Garmin eTrex Legend Cx GPS Receiver
ETREX LEGEND HAS 1 VERTICAL LINE ON SCREEN AND WONT SHUT OFF UNLESS YOU PULL BATTERYS
Have you updated your unit's software from the Garmin site? There was a new satellite launched in 2008 which has been causing problems, and the new update fixes this.
Mar 03, 2009 | Garmin eTrex Legend GPS Receiver
Best batteries?
1. Try fast recharging NiMH batteries. They will recharge in 15 minutes or so. There is also an option in the system menu to select which type of battery you are using - this will cause the battery indicator to provide a more accurate indication of remaining life.
2. Not really.
3. Garmin has a mac support page at http://www8.garmin.com/macosx/
Nov 18, 2008 | Garmin eTrex Legend GPS Receiver
Cannot install new Garmin eTrex Vista HCx to my PC
The driver file should be in a folder called USB_Drivers on the Trip & Waypoint Manager CD. The install process is confusing - it looks like it has to install twice as after the first time it looks for the file again - carry through with this the 2nd time and you should be fine. I have had to reinstall the driver several times over the last few years - also when using a different USB port. So now I keep the driver file handy on the hard drive to save getting the CD every time.
Nov 11, 2008 | Garmin eTrex Vista GPS Receiver
Display on etrex Legend is dim
Have you tried Main Manu / Setup / Display and then adjusting the contrast?
Jul 07, 2008 | Garmin eTrex Legend GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin etrex hxc gps adding m,ore map detail.
You will need to use Mapsource to transfer the maps to your GPSr unit. This should install when you install the Topo Britain program.
You will then choose which map segments you want to transfer, and the program will do the rest.
May 14, 2008 | Garmin eTrex Vista Cx GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
ETRIX MAY DISPLAY IS SHADED BLACK IN NATIONAL FOREST AREAS
You can adjust the CONTRAST setting on the GPSr unit. This should help.
Dec 07, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
442 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
