Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave
Model JVM140H002 I cannot figure out how to change the light bulb, not the one below that lights up the over and serves as the nightlight. I need to change the one that lights up the inside of the microwave. And, are there any restrictions on the bulb itself?
  • 4 more comments
  • mrsbrojoe Dec 27, 2007
    Are you kidding? Do I really have to pull the unit from the wall in order to change the microwave light bulb?! My husband has arthritic shoulders and I'm reluctant to try to do it "myself" - help!!!
  • repair man Apr 14, 2008
    How to do this, I have the same problem
  • Anonymous May 28, 2008
    What is the access to the GE JWP65 microwave interior light ?
  • Anonymous Mar 12, 2014
    change light bulbs in bottom of ge spacemaker microwave model jvm1631wj01
  • Anonymous Mar 16, 2014
    change the light bulb in my microwave
  • Anonymous Mar 25, 2014
    change light bulb in a panosonic microwave model#nm6372anm
  • GE Master
  • 9,149 Answers
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
Light is on microwave won't work
Posted on Apr 09, 2008
The spindle that turns the turntable is broke, where can i get one?
Posted on Mar 15, 2008
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
While changing nightlight bulb, it twisted off and short circuite
In all probability, the short took out the relay on the control board and the control board will need to be replaced.
I hope that helps.
Mar 16, 2010 | GE Microwave Ovens
Kenmore model # 721.62644200 light bulb over range not working. We think it is a relay on the circuit board but not sure. The push button switch works, gives feedback of being on, off. nightlight etc....
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 26, 2009 | Kenmore Microwave Ovens
Need to change light bulb
Enter the model number on one of two websites below to get parts and diagrams on how to access the light:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 27, 2009 | Microwave Ovens
Kenmore Microwave, overhead household, Model 721-6264900
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Night lights do not work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 02, 2008 | GE JVM1660 Microwave Oven
Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
NIGHTLIGHT WON'T WORK BUT SURFACE LIGHT WILL
This is a problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 09, 2007 | GE JVM3660 Microwave Oven
GE XL1800 Suface light
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jul 21, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,081 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
