Question about Pool & Spa
Can't get pump to prime
I can't get my jacuzzi pump to my pool to prime. When I put the water in, the pump just sucked out the water but doesn't begin to go through.
    New Friend:
  • 77 Answers
Is this the first time starting up this season? 1. Make sure pool level is up. 2. Check lid gasket and coat with silicone based lube. 3. Try to fill skimmer or drain line as much as possible. 4. If there ara two suction lines coming in then try to prime pump on just one of them. Gradually open second valve after prime is achieved. 5. If pump sits more than two feet above pool level then you will have to allow ample time for priming (it may take a couple of minutes).6. Make sure strainer drain plug threads are taped up. 7. If able to, try priming through another line.Good Luck
Posted on Apr 22, 2009
Pump air locked
Take lid if pump off, and fill with water.
Put lid back on and start.
if still won't prime, check orings everywhere Air can be sucked in.
System should be tight, so no air gets sucked in!
Jun 07, 2015 | Pool & Spa
My swimming pool pump is loosing it's prime
is there enough water in pool sometimes skimmers suck air also check the intake union of the pump you have a leak in one of your intake lines
Jul 12, 2014 | Pool & Spa
My pump is not primeing
most pumps that won't prime are not recieving a good seal on suction line (inlet) ck alll the fittings for good o-rings and ck filter lid as well , hairline cracks too can develop in hard plastic over time and rough treatment this can lead to loss of prime , one other reason and it's the most expensive reason is pump seal at drive end has went bad and sucking air if your handy with a wrench then you can source a new seal from jacuzzi if not replace entire pump (thats the expensive way)
May 10, 2014 | Jacuzzi Magnum Force Series Pool Pump 1...
Jacuzzi pool pump delivers no water
wow if it got that cold there id be winterizing with food grade antifreeze not just drainig it down, you could miss pockets of water here and there and produce a crack in housing someplace , as for trouble shooting a no flow situation try the ole standby method of methodical subsitution it's worked for 100 years , keep removing parts (start at suction line in pool) temporray out of system till flow starts then you know last part sub'd out was it!!!
Apr 23, 2014 | Jacuzzi Pool & Spa
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
We do not know where the air filter valves are
Air filter?
Remove the strainer basket cover ... fill with water ... check the gasket ... replace if questionable ... close the cover and SNUG the top down. Start the pump ... it should run just fine.
If you are sucking air, tighten the strainer basket cover a little.
Still sucking air? You will have to find the air leak. You might plug the leak with plumbers putty.
May 29, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi is hot heating
TIME TO BUY A NEW COMPLETE PUMP !! I RECOMMEND A STA-RITE DURA GLASS PARTS FOR THE JACUZZI ARE HARD TO FIND AND $$$ SCRAP IT REMEMBER TO PRIME YOUR NEW PUMP ... THUMBS UP IF I WAS OF HELP.. THANKS JAY.. THE POOL PUMP REPAIR GUY
Apr 03, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pool & Spa Logo
782 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
