Question about Dryers
Dryer does not heat
DRYER IS NOT HEATING
  • homeroslo Apr 22, 2009
    indesit dryer does not heat
  • 121 Answers
May be your element or thermostats
Posted on Apr 22, 2009
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Dryer stopped heating...what to do?
    Hello there
    Proper Voltage
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Dec 08, 2010 | Dryers
    My maytag electric dryer wont heat up
    Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    DRyer is turning just not drying clothes Maytag
    Hello there:
    Proper Voltage
    Jan 19, 2010 | Dryers
    Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
    Hello there:
    please try this
    Proper Voltage
    Will run but won't heat
    HELLO THERE
    There are 5 things that can make a dryer not heat please review the following items that i have provided for you
    investigate these five areas if your dryer is not heating up:
    Proper Voltage
    Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
    Dryer not heating. Toubling fine.
    hello there there are 5 different things that can majke your dryer not heat up please review these 5 things that i have provided
    Proper Voltage
    If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
    It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
    Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
    If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
    A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
    Jan 18, 2010 | GE Dryers
    Whirlpool dryer will not heat
    Hello there:
    There are 5 things that would not make the dryer heat up i will post you them here ok
    Jan 17, 2010 | Dryers
    The dryer does not give heat
    Hello there:
    Proper Voltage
    Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
    Dryers Logo
    91 people viewed this question
    Top Dryers Experts
