Question about Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
I turned on ps3
image showed for couple of seconds but then faded away
is plays audio but does not show image on tv when using av cable
the only time audio and image show is when hdmi cable is used
did video card burn out?
how can i fix it
    Scholar:
  • 39 Answers
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Posted on Apr 22, 2009
Ps3 turns on like normal but no image
Posted on Jul 18, 2009
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont show an image on to a tv.
try to reset your ps3. hold the power button and it will beep a couple of times do this three times. it will reset your system and work as long as you have no other issues
Jun 06, 2010 | Sony Playstation 3 (PS3) Console
No audio or visual via AV Cable
turn the power off in the back and then turn hold the power button in on the front then turn it back on in the back and continue to hold the front power button down for 5 seconds and you should here a beep then let go. Then turn it back off then on
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
I initially turned on ps3 system on tv. image
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Plasma shows rings of contrast around highlights & shows echos of what has been on the screen which last several seconds before fading away
This is common with plasmas actually. So long as the image fades and isn't a constant residual affect I wouldn't worry about it, but if it is constant and doesn't fade, its a sign of plasma burn out. The plasma in the tv has been active too long with one specific image or series of images.
Plasma televisions have been complained about because of this.
Sep 01, 2008 | Televison & Video
Ps3
You could have the wrong AV channel on your TV to the slot you have you PS3 plugged into your TV with.
Or you colud have set your PS3 to a HDMI setting while using a non-HD TV, I think there's a way to reset this setting on your PS3, check the manual.
Aug 29, 2008 | Sony Playstation 3 (PS3) Console
PS3 No signal to the TV
I'm having similar problems. I had my PS3 on pause, whent out for a couple hours, came back to find a weird fuzzy screen. My PS3 had froze, so I turned it off. I turned it on a couple minutes later, and the green light came on, however, my controllers would not connect, no image was popping up and it also wouldnt turn off unless I flicked the switch on the back. After contacting Sony, they told me it could be an overheating issue. If it has been less than a year, they will replace it, NOT FIX IT. Which is great and all, but unfortunately I am about to lose the countless hours I've put into assassins creed, skate, call of duty 4 and motorstorm.
HOWEVER. If your PS3 is still "functioning properly" except for no signal, turn the power off on the back, turn it back on, press and hold the power button on the front untill you hear the second beep, let go, give it a couple seconds, turn it off from the back and then back on, hold it till the second beep again. Good luck.
P.S. I recomend getting the extra cooling fan for it, and saving game data on another card (SD) incase crap like this happens.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Fading monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps, Good luck.
May 29, 2007 | Proview PL 766s 17 in. Flat Panel LCD...
Sony Playstation 3 (PS3) Console Logo
1,262 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
