Question about Foxconn 760GXK8MC-S Motherboard
WINFAST 760GXK8MC motherboard problem
I have put together a brand new motherboard, RAM and Sempron processor. I connected an ATX power supply and tried to boot the board by touching the power button pins together. The fan came on but I got no video output. I checked the power supply and realised that I did not have the 12V power supply connected for the CPU. I connected this and tried to boot the board again. This time the fan started for about a second then stopped. After a couple more attempts to boot the board disaster struck as a surface mounted chip began to fry. This chip is a 5 pin device, a few mm in size and is located close to Q59 and Q65. It is the only one of its kind on the board. Have you any idea what has caused this chip to destruct and also what the chip is so that I can attempt to obtain a new one and replace it?
    Scholar:
  • 35 Answers
It's possible that while booting your motherboard without the 12V power connected you physically damaged some components which eventually lead to the chip burning up.  However, it is quite possible that this motherboard was defective as Foxconn has discontinued it.  I would recommend RMA'ing (return merchandise authorization) the motherboard back to Foxconn.  While no one wants to wait for shipping it is probably your best bet.  Even if you order the chip that has been damaged, and can properly solder it back in place, there will most likely be other physical damage that is not visible to the eye.  I would recommend another motherboard, and Foxconn has quality mobo's for around $50.  Try visiting www.newegg.com. Hope this helps :)
Posted on Apr 22, 2009
Hi Hope you can help my mother board is K8M890-M2MB-RS2H Processor a Main Circuit Board b 2.20 gigahertz AMD Athlon 64 X2 Dual Core Windows 7 Ultimate (build 7600) I am looking to upgrade...
As long as it is an ATX compatible power supply increasing the available wattage is not an issue, only meeting MIMIMUM power requirements
You can go to a 500, or even a 750 as long as it has the correct motherboard connections
Aug 03, 2011 | Foxconn WinFast K7S741MG Motherboard for...
Computer wont start after pressing the power switch.. the processor fan stops together with the power supply...what will i do...i already check the power supply, memory and the different cables inside the...
check *********** board if there are some capacitors that are deformed, busted parts may do the problem , try first to pull out socket,connections then place it back again 2-3 time to avoid corrosion.
Jul 07, 2011 | DFI NF3 250-AL NVIDIA Socket 754 ATX...
The controller will not turn on. Green light on back comes on but when we turn on the unit, the fan starts briefly and then the power cuts off.
Bad Power Supply. Weak Voltage power rail.
Not enough power to turn the Processor on, and keep it on.
1) ALL those LED lights together, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is. (Older Processors use less Wattage)
The Compaq Presario SR1810NX desktop computer, comes with an AMD Sempron 3200+, processor.
(Uses the Socket 939 processor socket)
[Maximum operating capability is a 1.8GigaHertz frequency rate.
1.8GHz
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
Frequency Rate is correct computer speak for 'Speed'
The AMD Sempron 3200+ processor, can operate at a maximum frequency rate of 1.8 Billion Cycles per Second ]
HP Support >Compaq Presario SR1810NX desktop computer > Product Information > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00609384&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=1841795&lang=en
The AMD Sempron 3200+, can use up to 62 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Palermo.22_.28Socket_939.2C_E3_.26_E6.2C_90_nm.29
(Palermo Core)
When you press the plastic Power On button, you are contacting a Power On switch inside it.
(Typical ATX Power On switch,
http://www.directron.com/atxswitch.html )
When an ATX power supply is plugged into power, there is a 5 Volt Standby power, present inside the power supply.
Pressing the momentary contact power on switch, closes a circuit that directs the 5 Volt Standby power to 'excite' the power supply, and turn it on.
The first chip to receive power is the BIOS chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit.
BIOS stands for Basic Input/Output System]
BIOS,
http://en.wikipedia.org/wiki/BIOS ]
BIOS looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S. Operating System)
The LED lights receive power, so do the fans, and the Harddrive. When it's time for the Processor to kick on, there isn't enough power, and the Power Supply 'falls to it's knees'.
Replace the Power Supply.
It's just one of the basic ATX power supply's that are readily available in a multitude of places.
The Wattage is 300 Watts.
The ATX form factor for this power supply, (Size and shape), is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
Power cables needed:
(Continued in a Comment)
Aug 02, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
I have a Winfast K7S, 741M01C, series motherboard
Hello Friend,
The max RAM that you can use with this motherboard which has 2 RAM slots is 2GB.
Best Regards,
Oct 30, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Currently has 2600+sempron at 1.6ghz, want to upgrade processor, what is the maximum this board will take
His Motherboard is a Foxconn/Winfast 760GXK8MC-S , which rather annoyingly is not listed on foxconns support site so im thinking its an oem motherboard
Some quick googling shows:
AMD Athlon 64, AMD Sempron With FSB 1600mhz
Sorry that i cant be of any further help ,
If you found this useful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Foxconn 760GXK8MC-S Motherboard
Winfast 760GXK8MC 754 SEMPRON aTHLON 64 pROCESSORS
disconnect all external devices and then bypass the UPS and plug the power cables, monitor and computer, into wall socket outlets. Make sure and disconnect any ethernet cable as well.
Jun 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Powers on but no video.
Your motherboards RAM is not working properly. First you try getting it out and installing again. If that not work you can change with other one.
Feb 09, 2008 | EliteGroup nForce3-A Motherboard
Viper MSNV-939 ATX Socket 939
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop. Also assuming you bought the ram from the same place and is compatible with the board. Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual. The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip. That's not to say that the motherboard was'nt faulty in the first place.
Apr 18, 2007 | Mach Speed (S755) Motherboard
Foxconn 760GXK8MC-S Motherboard Logo
1,635 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
