Harman Kardon AVR 140 Receiver Logo
A
Anonymous Posted on Oct 07, 2013
My control volume don't works , but the light is on
Need driver headphone jack
Bob.......what operating system do you have?
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 • Music
1helpful
I HAVE A NOISEY VOLUME CONTROL ON MY AMPLIFIER IT CRACKLES HOW CAN I STOP IT
No fear.
Try to reachinternal side of front panel with volume controls. Put some paper towels under the front panel. Pour lighter fuel into every dirty volume control turning knob around several times.- It will rinse out all dirt from carbon track or contacts. (I don't know what kind was used).- This is only temporary solution, good for one year or so. Proper solution-> unsolder volume control, open it up , inspect and clean or replace for a new one. It will work, I did it hundreds of times...always with positive results.
I have a panasonic th42px60u my problem is that none of the controls work except the on and off volume is on but unable to increase or decrease the volume. What part do I need to buy to fix the problem,...
Good day Mr.Daniel Navarro..
The picture below is the sample 42" plasma TV (internal parts)..
If your TV won't adjust volume or change channel by pressing button on the front panel..The problem could be the digital control board,it is the one that have a rectangular red on the image shown..
But before you replace the board make it sure that the control button assembly is properly connected on the said digital control board ( no loose connection or loose solder)..
Also try this remedy:
If you have remote control you can use it for the mean time to adjust the volume and channel so that you don't need to replace the digital control board..
Hope it helps..
Thanks for using fixya and purchased my service..Please don't forget to rate my answer..
My dish remote does not work on my new RCA tv. How do I fix that?
Hey Vernon Long,
We would have to program your remote to your RCA TV. I have provided the steps to program the remote below along with a few codes to try. You can view the link provided for more codes if the ones I list don't work!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Codes: 502, 646, 633
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Our remotes aren't guaranteed to work all types of equipment, but if the codes don't work let me know here and I will try some more steps with you!
Tommy Faust
DISH Network
How do i sync my ir Dish Satellite remote so my Sony NSG-MR1 remote will work for Dish
Here are the directions to do so:
1. Hold down the clear TV button on the top of the remote until all lights light up
2. Put in a three digit code (provided below)
3. Press the # (POUND) button
4. Try the TV power and the volume. If both of these don't work, try another code.
500
000
Becki Barned
DISH Network
Customer Service
My stereo is stuck on one station, dosn't light up wont turn off/on \r\nthe volum control not working, cant change station, I don;t know whats going on with it !!! It worked fine yesterday
check all of your fuses, the radio has 2 power feeds, one for the operation and one for the memory, if the memory feed is out the radio will work partially like you explained
I bought a new TV and need to program my Dish network remote control
Hey scrappy32847,
Congrats on the new TV! I can definitely assist you with this and get it taken care of. As I don't know what TV you have I don't have any codes off hand available.
You can check out this link: http://www.dishnetwork.com/SupportSection/remote-setup to get the codes to program your remote. I have also listed the steps below to program that remote to your new TV.
If you need any additional assistance you can reach me here or at [email protected]
Tommy Faust
DISH Network
I have a 2004 Jeep Wrangler. The Engine light came on. I had Auto Zone check the code for me. I don't remember the number, but they said that it was the Purge Valve. I had to buy the Purge Valve from...
Could be the P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
The EVAP canister purge volume control solenoid valve uses a ON/OFF duty to control the flow rate of fuel vapor from the EVAP canister. The EVAP canister purge volume control solenoid valve is moved by ON/OFF pulses from the ECM. The longer the ON pulse, the greater the amount of fuel vapor that will flow through the valve.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Damage harness or connectors to the Purge Control Valve
- The valve circuit is open or shorted
- EVAP canister purge volume control solenoid valve may be faulty
When is the code detected?
- An excessively high voltage signal is sent to ECM through the valve
Try to remember this code number for additional details. Hope this helps, keep us updated.
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
