Question about Sony KV-27S22 27" TV
On/off light keeps blinking...
When I first turn on the set, but never turns on. Normally it would take 10 to fifteen seconds to turn on and the blinking light would stop. One day it just stopped turning on and just kept blinking. Please let me know if there is a solution. Jack
  • KSK krew Jul 29, 2008
    My I-pod 30gb was in my purse and accidentally spilled into the toilet, it was only a second and it was barely wet but now it won't stop blinking white, it's been doing this for the past day.
    I tried to restart it but it simply will not do anything. I even tried connecting it to the computer to see if would just go back to normal but it still won't do anything and Itunes doesn't say Nicole's Ipod, it acts like nothings connected to it.
    Begging for help!
    My I-pod is pretty much my life.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is a power supply failure in your tv. it is a simple problem but can be rectified by tech.person only. good luck
Posted on Sep 25, 2007
6ya staff
SOURCE:
Lenovo idea pad 300 won't turn on. Red power light blinks 3times then switches off. Rebooting doesn't work. Tried different adapter. Power on Lenovo screen appears for 5 seconds then goes black.
Sometimes they 'crash' in sleep mode. Try hold the power button down for 10 seconds. This should make it reset. After the 10 seconds, release the power button. Then press it again to turn it on normally.
Oct 09, 2017 | Lenovo Computers & Internet
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
Sony bravia turns on and off by itself then stand by light blinks 10 times
Google the model number of the set(not indicated here) for "error codes" or 10 blinks---Also look on the Sony site for this information--you can call them with the model number also.
Apr 16, 2012 | Televison & Video
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
Jan 14, 2011 | Saturn SL2 Cars & Trucks
2000 pontiac montana doesn't start and security light appears on dashboard
Very common problem on these cars. Do you have another key you can use? Try it. If not take the key ou have been using and turn ket to the on posistion. Leave it there on for ten to fifteen minutes. The computer will relearn the chip code on key. When light stops blinking you know it is done. Turn key to off wait ten to fifteen seconds and turn key to on position, Security light may blink once or twice then it should stop.. Try to start vehicle. It should start. If it doesn't then you may need whats called a new passlock and possibly key reprogramming. Which can only be done at the dealer most of the time. Hope car starts with the first procedure. Let me know if it works.
Oct 26, 2010 | 2000 Pontiac Montana
How to resit service light on VW passatt 1.8T 2002
Try removing the negative and positive lead on the battery for fifteen seconds. Then, hold the contacts together for 10 seconds and then reinstall them. Next, leave the driver's side door OPEN and turn the ignition switch to ON (but DO NOT start the car) and let it remain there for 30 seconds. This should reset the check engine light.
Feb 22, 2010 | Supersonic Car Audio & Video
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Sep 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
Computers' power light is blinking and will not power on
This normally means that the computer is in standby mode all you need to do is press the power button. If this does not work then hold the power button in for about 10 seconds until the computer turns off then wait a further 10 seconds and turn back on and boot normally.
Please let me know it this works and please rate me. Once you booted normally set the power options within control panel not to go into standby.
Cheers J
Jan 01, 2008 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
Problem
hold the power or reset button in for five seconds
Oct 09, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
