Question about Konica Minolta bizhub 350 All-In-One Laser Printer
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
The Konica Minolta Di3510 copy machine.
The ADF causes paper jamp or may bend 1 corner of the paper.
The copies also have a crooking line and weir image when copying.
    Problem Solver:
  • 17 Answers
Check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Posted on Jul 07, 2009
    Problem Solver:
  • 15 Answers
Hi, clean the front roller take up ADF with alcohol and the little glass
Posted on Jan 15, 2010
    Sergeant:
  • 210 Answers
Check on each end front rear on ADF paper path
ther must be a paper clip , staples, a little teared paper jammed. and clean the **** glass or scan platen glass. on the left side.
Posted on Jul 09, 2009
  • agus tiwansyah Jan 23, 2016
    sir.. would you help me please, my adf is working good. but theres no print out after copy from adf.. so confused.. thank you
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
My Adf its not working properly it scan only half of page.
This is simple. There are a bunch of sensors in the adf that read the paper size. Your adf is telling the copier that your copying 8.5x5.5 that's when the copier blanks out the rest of your page. So do u have any scrap of paper or sensor that is blocked they have spring loaded flags on them sometimes the spring will fall off and cause this so look very carefully and you will find the little sensor that is causing your problem. Also there are photo sencors that get dusty. So use canned air to clean them out but be careful you could knock off the springs on the flags with air.
Oct 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
Minolta 4000 how to remove the C-40 code
One of the copier fans is bad. Open close the front door. to reset
Mar 29, 2014 | Minolta DiALTA Di183 Copier
How to add konica minolta bizhub Di3510 on windows xp
Down load the driver from konicaminolta or use the disk with the copier.
Jan 22, 2014 | Minolta Di3510 All-In-One Laser Printer
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,057 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
