Question about Panasonic Televison & Video
Many stations are cut off other TV on same cable are OK
Many sites signal ''no signal'' otghers have a lot of static.
  • jgoodner Apr 23, 2009
    Tv is connected to a local cable carrier,Cunningham cable in Belleville, Ks. TV model is Polaroid 19" TV and DVD combo 1913TDXB. Yes, in the US. 3 other tv's also on the same cable but not having any trouble.
  • jgoodner May 04, 2009
    I found that the TV was defective and returned it to WalMart.Thanks for your help
    Sniper:
  • 86 Answers
Hi, I'm happy to assist you with your problem. Can you answer some questions to help me get a better understanding of your problem?
1. How do you receive your television signal? Cable, Satellite, Antenna (indoor or outdoor)? If cable or satellite, who is your provider? (eg. Comcast, DirecTV, etc.)
2. What is the model of your telelvision?
3. How long have you been experiencing this issue?
and finally...
4. Are you located in the US? (some stations are changing the way they broadcast, that's why I ask)
Thank you for taking the time to help clarify... I'll get back to you as soon as you post the answers to the above questions.
Posted on Apr 22, 2009
  • 1 more comment
  • OnlyOneN
    OnlyOneN Apr 23, 2009
    Thanks for your reply! Two things to try:
    1. Replace the cable that runs between your TV and the incoming cable line. (This may be on the wall, or through the floor, depending on how it's installed) I'd use one of the known-good cables that is currently on one of your other TV's.
    2. If that doesn't fix it, then go through the Channel Scan function. You can find out how to do that by looking at the user manual (pg 19) located here: http://www.polaroid.com/service/userguid...
    To summarize:
    Press the INPUT button on the remote to display the Input List. Use the ▲▼ buttons to select TV and press the OK button.
    Press the MENU button on the remote control to display the Main menu, and use the ◄►
    buttons to select the TV.
    Press the ▼ button to select Channel Scan, and press the OK button.
    The Channel Scan automatically creates a list of receivable channels. Press the
    MENU button at any time to interrupt the memorization process.(the list cannot be
    created if interrupted)
    Press the OK button to display the received channel list, then press ▲▼ to select a
    channel. Or, use the ▪ (INPUT button) with 0-9 buttons to select digital channel( for
    example 9.1)
    This is all assuming, of course that you're not using a cable box to tune channels. If that's the case, let me know.
    Finally, as one more troubleshooting option, try taking one of the good TV's and plugging it into where you have your Polaroid currently hooked up.
    Let me know how it goes, and good luck!
  • OnlyOneN
    OnlyOneN Apr 27, 2009
    Any luck?
  • OnlyOneN
    OnlyOneN Apr 29, 2009
    Is it working?
Sharp Aquos LC-52D92U static on display
if your seeing static on a digital tv , your problem is "Not" in the tv its in the signal source (cable box, sat scram,Etc)
digital tvs cant produce "static" displays because they don't receive wide spectrum signals like analog TV's did (carol-ann knows this!) there "filters" are very narrow and specific , this is also why there range is dramatically smaller than analog tvs
also everyone by now knows that tv stations can no longer transmit in analog format (in Usa), G4 cell phones got there band space
Jun 29, 2015 | Sharp Televison & Video
The bit error level is 10 on the Ch7 stations but ok on all other stations and the signal strength is around 50 Any idea how to fix. Plugged in a different smaller TV into the same coax cable connection...
Plugging in a different tv does not really prove much, tuners vary slightly in the way they handle signals It may just be that your aerial needs a very slight adjustment or has degraded slightly.
Can you plug the coax into another device (vcr?) and out of that into the tv and see what happens?
vote appreciated
Feb 03, 2011 | Samsung Televison & Video
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Aug 05, 2010 | Axion AXN-8701 7 in. Portable TV
My tv comes on and has "unusable signal" floating on it
What is your signal source, OTA or cable? Did lightning or another type of power surge recently hit? Make sure you have the TV on the desired input.
If OTA check your antenna direction and that you have the Channel Setup (from the menu) set to Antenna. Also check if you have the right antenna to get stations in your area. Antennaweb.org gives the most likely channels and directions. tvfool.com will give more detailed information and more stations. Both sites assume outdoor antennas but the direction information is always good. Look for new construction or big trees that might block the signal. Do you have multiple TVs sharing the same antenna? You might need an amplifier.
If cable, check the Channel setup. Check for someone recently damaging your cable installation (cutting the wires, trying to split the signal to get it for free) Splitting the signal to multiple TVs may also be an issue, get an amplifier of the correct type. Some cable systems may require a bidirectional amplifier.
If you recently had a power surge, see if the TV works with other inputs.
Tuners can be replaced if the TV is worth the labor costs for you.
I hope this helps.
( My household had three tvs and a digital to analog converter that lost their tuners after a nearby lightning strike. We chose to replace the TVs since two were over 15 years old and the third was also out of warranty.)
Apr 13, 2010 | RCA L46WD22 Television
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Stereo signal bleeds through
DO YOU HEAR IT ON ALL CHANNELS?, DOES THE SHIELD ON YOUR CABLE HAVE A CUT IN IT? HOW CLOSE IS THE RADIO STATION?
Dec 12, 2008 | Toshiba 57H84 57" Rear Projection...
Open Questions:
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
