Question about Sony CDX-GT210 CD Player
Not working at all
I tried to install it on toyota 1992 camry and it seems i didn`t do a good wiring , at first trying it works for seconds and it took the cd and then nothing.. although the fuse is good. after doing the wright wiring no change , i cann`t get anything to work on it...
Haha
Posted on Apr 11, 2008
Where can i purchase an engine wire harness for a 1993 toyota camry v6
try a wrecker they dont sell wiring much so should be cheap enough
Nov 14, 2012 | 1992 Toyota Camry V6
Engine light came on
Make sure your gas cap is tight, at least 5 clicks, sometimes a gas cap that doesn't seal tight will trigger the Check Engine Light. If the light stays on you will need to pull the Trouble Code from the ECM (Computer) using a OBD II scanner.
Jun 16, 2010 | 1999 Toyota Camry
Car wont start on my 2003 toyota camry. all light are on bright, but wont turn over. car was working perfect all day. new battery brought in nov.09.
give the TBAR assembly a shake and make sure the park pawl operation is working try to start in N (always with foot on the brake) if Auto... if manual push the clutch pedal in and start if still no good check starter motor connection all wires on give the starter a LIGHT TAP with a small hammer in the smaller of the two cylinders get someone to crank while your doing it watch your fingers
Jun 05, 2010 | 1992 Toyota Camry V6
I have a 1992 toyota camry that is hesitating and trying to stall
yes basically there usually held on with a couple of bolts
Apr 29, 2010 | 1992 Toyota Camry V6
My 1992 usa 2.2 camry won't start. the spark looks weak
have your timing belt checked. and your wires replaced. well the ones going from the distributor to the spark plugs.
Feb 23, 2010 | 1992 Toyota Camry V6
I need a spark plug wire diagram for a 1992 Toyota Camry 4 cylinder
1992 Toyota Camry Sedan
3.0 liter DOHC V-6 (3VZ-FE)
Cylinder # Front, passenger to drivers side 2-4-6
Cylinder # Back, passenger to drivers side 1-3-5
Distributor 12 O'clock post # 6 cylinder
10 O'clock post #1 cylinder
8 O'clock post #2 cylinder
6 O'clock post #3 cylinder
4 O'clock post #4 cylinder
2 O'clock post #5 cylinder
Good luck and hope this helps.
Jan 12, 2010 | 1992 Toyota Camry V6
1992 camry 3000 v6 gas rich exhaust smoke
injectors ,when dirty, tend not to spray as well,so it might be that......try some fuel injector cleaner. Also if you have a bad o2 sensor .The o2 sensor tells the computer how to mix the air and gas mixture
Jan 21, 2009 | 1992 Toyota Camry V6
1992 toyota camry
hello i have a 1992 camry 4 cyl. i did a tune up on it(spark plugs & wires,air filter,fuel filter,dist. cap rotor) engine light is on now. It shuts off after 5 minutes of driving or idle. could it be a sensor? if so what type? thanks
JC-
Aug 29, 2008 | 1992 Toyota Camry V6
Sony CDX-GT210 CD Player Logo
63 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
