Question about Philips 42PFL5603D - 42 IN. LCD HDTV
Looking for replacement panel for Philips 42'' model #42pfl5603d
I have a broken screen on my lcd tv. I'm looking to replace the panel using a similar screen. Does anyone know if I this panel is interchangeable with another model number or brand? eg: LG
  • abdeel10 May 05, 2009
    i have the same problem, I´m still looking for remplacement
  • Philips Master
  • 1,212 Answers
Visit Anrews Elctronics.com. Ask for a salvage part.
Posted on Dec 25, 2009
Power to the tv does not stay
from looking at a picture (i found) of the power board there could be a fault with the capacitors the three next to the heat shield. it is on the power out part. this area would be prom to get hot and weaken the capacitors. check them for rounding tops. replace for like to like.
Sep 21, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
My phillips lcd 46 The GREEN light blinks on it come on black screen the it goes off again and does some thing over and over just got this tv new three days ago model 46PFL5705D
This tv is having a power supply board issues,that the electronic board where the tv power a/c cord plug into it.This is a new tv.Return the tv where u bought it quickly and get a new tv replacement.
May 08, 2011 | Philips 42PFL5603D - 42 IN. LCD HDTV
Lines going through the display of my Philips LCD TV 42PFL5603D Philips 42", making the picture unwatchable, sound is not affected
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. The entire board costs around $250 right nowbecause they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shutsoff on its own problem. I'mworking on uploading pictures to help guide people though the process aswell. Let me know if I can do anythingto help. Hope this helps and Good luck. Kaufman605
Dec 12, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
I have philips 42'' lcd tv its only 14 months old i have no picture but have sounnd is my tv still under waranty thanks gary
You need to replace the SSB [small signal board] I don't beleive warranty work will cover this. Reach into your pockets for this one! Sorry!
Mar 14, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Black screen when I turn on my 42in Flat screen
Do you have audio? Anyway, you will need to replace the signal board. Ask a TV tech for pricing and labor! Sorry!
Have no picture but still have sound Philips 42" Widescreen TV
you are gonna have to take this apart,lay flat on table to remove the cover.first look at the power supply board,you are looking for swollen caps(round canaster-one side is marked - in black meaning negative.this tv came with 2 versions of power supply.part numbers 272217100569 phillips or DPS-279CP A delta.if you do not see any bad caps look for a bad fuse,replace if bad.if it blows the fuse again inverter boards,part numbers 6636L-0022A and6636-0021A.all of these parts are available at shopjimmy.com,just type in model number,scroll down to find any of these parts.
Sep 24, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
TV will not go into standby mode
You may have to unplug the tv from AC power for a few seconds and then reaaply the power! Or replace the small signal board.
Sep 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Philips 42'' flat screen
Bring your TV to eletronics technician. The main power of your TV has a broken semiconductor parts that need to be replace. ( Maybe power mosfet, fuse, transistor, capacitor, etcc ).
Jul 23, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Philips 42inch LCD flat screen tv
It could be a Power supply problem or a Main Board problem. Best to have a Pro look at it for you.
Jul 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Replacement lcd screen
I have broken Screen how or where can i replace it? (model 42lc7d)
Jul 31, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips 42PFL5603D - 42 IN. LCD HDTV Logo
1,046 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
