-   Just normally using my desktop and suddenly my LG monitor says out of range 91.4kHz / 115Hz
in order to make it back is to restart the cpu, but the problem is, when im downloading such a big file, it will not be save, especially when im halfway done..
-   Guest
Mar 14, 2009
-   My son tried to play Maple Story (A web based game) when the screen went blank and a small blue box in the middle says "Attention Out of Range"
-   sirenmedea
Mar 14, 2009
-   My son was trying to play Maple Storey which he had played before. Suddenly the screen went blank and a small blue box showed up with the message " Attention Out of Range H: 255.0KHz V: 239.0Hz" We tried to reboot but it does the same thing and cant even get normal viewing on the screen at all now.-   sirenmedea
Feb 15, 2009
-   help me
-   Guest
Dec 08, 2008
-   Using Planar PX171M-SI monitor. Worked well until I decided to use monitor with another computer. This other computer had a 19" Sceptre LCD and worked fine. Computer will boot, Windows screen shows, then screen goes black and flashes "out of range." Computer will boot in safe mode, however, with normal monitor operation. Operating system on new computer is XP Professional.-   wstauffer
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
I have a 20"Optiquesr monitor with HP vista computer. Ocasioally. the moniter reads "Out of range" The instructions that came with monitor says to set resolution 1680X1050 but it still has the out of range ocassionally
upgrade drivers, i could not use one of my games, then i got drivers for both video and monitor, works fine. the monitor driver says fp371 but still fixed so no problems!
Was this helpful?
Yes
No
Solution #8
posted on May 27, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
adasdasd
Solution #9
posted on Jan 07, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Nah i tried all these things and it has not helped, i am starting to think it is more of a virus issue then my monitor. i appreciate the help all.
it was only happening on one game, then it started to effect my other games and it is now at the point where i can even use my computer.
The Dell Dimension XPS 8300 system is automatically disabling the nVidia GeForce FX 5200 driver...
(More)
The Dell Dimension XPS 8300 system is automatically disabling the nVidia GeForce FX 5200 driver (Dell-installed) and defaulting to a generic VGA configuration. As a result, the images on screen appear elongated (vertically) and shortened (horizontally). Everything appears too tall and skinny. I have tried multiple reinstalls, deleted the driver, rolled it back, etc. When last I tried to uninstall the driver I got a message indicating that cant be uninstalled because the driver is needed for the system to boot. How do I fix this? Your assistance is appreciated. .
I have a 2007 47" viewsonic that is deciding on it's own to show in letter box, wide screen ,...
(More)
I have a 2007 47" viewsonic that is deciding on it's own to show in letter box, wide screen , normal and so on. Never a problem till now.
My monitor is black and says out of range. I turn the computer off to re-boot and I see the Dell scroll, along with the Windows XP label scroll. Then monitor goes black and flashes this Out of Range. Why? Anything I can do to fix it? Is the problem with the computer or the monitor?
i was installing an operating system, after the installation i restarted the computer and suddenly the monitor turns white and an out of range appeared...........what kind of problem is this?
Comment by Guest, posted on Jul 06, 2008
My monitor just gave me a message out of range, the screen turned black, anything I can do????
Comment by Guest, posted on Feb 21, 2008
when I turn on my computer after a while my monitor turns black and it says out of range.
I hooked my monitor which had been working fine on an old desktop to my HP laptop. It worked for a little bit then went black. Seemed to be powered off. I worked with the power cord and got the power back but the message Out of Range appeared on the screen.,
