Question about Amana D545M Dehumidifier
Stopped Draining through hose
Fills the tank only
  • gbar2 Apr 22, 2009
    Water never gets to the hose, how is it routed fills the tank?
    Is there an overflow
  • 10,865 Answers
The hose must be plugged. Empty the dehumidifier, disconnect the hose and see what the blockage is, then remove it or get a new hose.
Posted on Apr 22, 2009
I have attached the hose to the Danby dehumidier and put the water tank back into the machine. I pressed continuously flow and the humidity indicator is at 87 The water tank was full later with the...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 14, 2017 | Danby Dehumidifiers
Water fills in the bucket and will not drain
I've got the same problem. It drained through the hose for 6 months, but recently stopped and now fills the bucket. I connected a new hose, but that didn't help. I found some debris inside the dehumidifier (where you connect a hose to), but removing that didn't help. I may try taking the unit apart to see if somehow a cricket or some sludge got built up inside.
I'll post my findings. Hopefully it won't be too complex or nasty!!
Oct 06, 2010 | Frigidaire FDF50S Dehumidifier
Have hose hooked up but it does not drain. Compartment fills with water and needs dumped manually. Want the hose to work so twice-a-day dumping in basement not needed. Thanks!
You connected a hose to the hose outlet on the catch tank ... right? The tank will not drain even though there are no kinks in the hose and the end is lower than the tank, right? Did you put a hole in the tank before you attached the hose? I will bet not ... and I will not laff at you ... I did the same.
Put a hole in the tank (where the hose attaches), reattach the hose and all will be well.
Thanks for your interest in FixYa.com :-)
Aug 09, 2010 | Soleus 30-Pint Dehumidifier
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
May 04, 2010 | Whirlpool AD50USS Dehumidifier
D530M Dehumidifier---Have the hose hooked to the back but the tank fills up and shuts off. What do I need to do to make it self draining?
Dumb question, is there a hole in the tank where you attached the hose?
Check it. remove the hose - look closely - If it doesnt have a hole in it ... put one in it
and I promise I won't laff ...
same thing happened to me
a
Oct 01, 2009 | Dehumidifiers
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Sep 11, 2009 | Maytag M3DH30B2A Dehumidifier
Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Sep 24, 2006 | Danby DDR2504 Dehumidifier
Amana D545M Dehumidifier Logo
254 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
