How to get files from old computer to transfer to new one
    Novelist:
  • 133 Answers
It depends on the amount of data you want to transfer to the new computer ... There are multiple ways you can transfer data.
1) You can just transfer the files from the old computer to the external storage device like CD or Pen drive and hen connect the media to the new computer and copy the data from the storage to the new computer .. This would work if you want to transfer few hundreds of Mega-bytes to few Gega-bytes of data.
2) However if the amount of data to be transferred is hugh then you might want to use NTbackup program that comes along with Windows XP Professional and then restore the backup on the new computer.
3) You can connect the old computer's Hard-Disk to the new Computer and copy the data from old Hard-Disk to the new one.
There are other methods too however these are the most common and most widely used methods...
Please let me know in case there are any doubts and please do not forget to rate the solution if you liked it.
Thanks and Regards,
Srinivas
Posted on Apr 22, 2009
    President:
  • 1,383 Answers
U can take backup of data by harddisk to harddisk.
Connect your old computer harddisk to new computer then simply power up the new computer then u find both harddik then simply take backup of old data to new computer.
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Synching Itunes
To Transferring Playlists
If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop.
Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing.
Source:http://support.apple.com/kb/HT4527
Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
Dec 02, 2011 | Apple iTunes
How to download my file from my old computer
The simplest way to transfer files from your old to your new computer is by using USB flash drives. Just save your files from the old computer onto the flash drive then plug this USB drive in to the new computer and save the files there. If you have large files, you can also use an external hard drive to copy and transfer files.
Mar 22, 2011 | Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
Transfer music from one ipod to another
I recommend you am iPod to iPod/Computer/iTunes Transfer which can transfer your iPod and iPhone music, video, playlist, photos back to computer and iTunes.
If you own more than one iPods, AVCWare iPod to iPod/Computer/iTunes Transfer can simultaneously manage all the iPods in the same interface, you may transfer files among these iPods by drag-and-drop.
Hope it helps!
Apr 12, 2009 | Apple iPod MA446LL/A MP3 Player
Trying to transfer files from old computer to new computer
both computers with USB?then buy a cheap flash drive and do the job if you are technically challenged...
both computers have internet?
compress your files in your old computer in ZIP..upload to sendspace.com ..on your new computer download your files :)
pull your hd from the old pc and hooitup to your new computer..lots of options that I did not mentioned...
Feb 05, 2009 | 3Com Computers & Internet
I am trying to transfer files from an HP with Windows 95 to my HP Laptop with Windows Vista. My old computer tells me that I do not have the proper driver installed. What to I need to do to install a...
You cant transfer files from your old computer with Win 95 Using windows easy transfer which is a file transfer software in vista . If you want to transfer files then you have to copy them on a cd or dvd then paste them to your new computer . It will take a lot of time . Call a computer expert and tell him that you want to transfer the file from your old computer . He will do that easily .
Please rate me .
May 14, 2008 | Computers & Internet
Transfer info
Windows has a 'Files and Settings Transfer Wizzard' where you can transfer files from your old computer to your new one.
Click on Start . . .
All Programs . . .
Accessories . . .
System Tools . . .
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
