Question about LG 42PC3D 42 in. Plasma Television
How to connect to digital cable box and TIVO
I am having problems receiving sound on TIVO recordings for channels above 100. I can't find a diagram for the proper connections for my TV, my Motorola DCT5100 digital cable box, and my TIVO Series 2, dual tuner DVR.
  • 86 Answers
Click here and start at page 24 to see a diagram on how it should be hooked up.
Posted on Jan 22, 2008
SOURCE:
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
My cable company just went digital. I have a TIVO
you will have to hook the tivo to the cable box and reconfiger, you will have to hook up the ir eye from the tivo to the box so thay can talk. the newist tivo is realy cool it take a cable card and can record muilt chanels but your old one when configured with the cable box will only record one chanel at a time and you wont be able to watch another channel wile its recording
Apr 15, 2010 | Vizio L32 32 in. LCD HDTV
Changing Channels with Series 2 Tivo
Make sure you are using the IR cable to control the Cable Box.
Make sure that you have already done a guided setup again from the tivo box.
Jan 04, 2010 | Tivo Series 2 80-Hours Video Recorder
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Sep 12, 2009 | Tivo Series2 TCD649080 Video Recorder
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Tivo & cable
Have you gone through the automated set-up again, to let the Tivo detect what channels you have and don't have?
I had a similar issue a few years back when Comcast changed our line up, and that solved it for me.
Jul 12, 2008 | Tivo Series2 TCD649080 Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
LG 42PC3D 42 in. Plasma Television Logo
598 people viewed this question
Ekse
