Question about Edimax PS 3100A+ (PS-3100A) Print Server
Problem edimax ps3100 printserver
After i installed the drivers for the edimax ps3100 i could not add or delete any printers anymore in vista.
when i try vista says "because of limitations" it can not add printer ask the system controller.
I am the controller and did not add any restrictions.
i can not go back with system restore because all the backups are witch the drivers installed.
deinstalling the driver does not solve the problem
how can i correc this problem
please help
3 Suggested Answers
  • 76 Answers
SOURCE: Problem with Canon I-SENSYS MF 4150
Wondering why you changed to a new Canon driver? With the new driver, this print server may not work, no IFs, ANDs or BUTs. Most print servers (not all though) don't work well with a multi-function printer. This one probably changed due to software programming in the new driver. All you can really do is return to the older driver, or buy another type of print server. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • 3 Answers
SOURCE: PS3207U problem with HP 1060
Same problem with a Hp 3300 and a Hp960c, both of them plugged and recongnized by the unit, there was no way to print.
Then I upgraded the unit firmware to version 1.3 and now both printers are working!
Posted on Apr 02, 2009
I have windows32bit OS installed printserver and I want to add x64 it driver for Ricoh MPC5000 multi function printer, I downloaded windows 2003 64 bit driver, but it shows error. how can install it?
Hello.
Not sure if it is possible. X64bit drivers are written for a processor capable of handling 64bit commands, trying to install them on a 32bit CPU simply wont work.
Sorry for the bad news Regards GM
Aug 01, 2011 | Office Equipment & Supplies
Tip
Configuring NETGEAR print server PS121 printer port settings manually.
If you can not run the installation software for the print server PS121 on the computer then you can try the below steps to manually configure the printer port settings:
Step 1:-
1. Visit the link below to make sure that the printer is in compatibility list:
http://kbserver.NETGEAR.com/kb_web_files/n101216.asp
2. Make sure that the printer is working in direct connection with the computer.
Step 2:-
1. Now connect the printer to the USB port of the printserver and then the Ethernet cable from the router to the Printserver Ethernet port.
2. Press the DIAGNOSTIC tool button on the printserver for 10 sec (All the lights will blink amber), you will receive a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router. If there is no ip address then powercycle the router, printserver and the printer. Press the diagnostic tool button again.
Configure printer port settings on XP computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Configure printer port settings on VISTA computer:
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
These steps will help manually configure the printer port settings on the computer.
on Feb 10, 2010 | NetGear PS121 Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
How to setup print server model 1205Mf for xp and vista
Whatever the model is, or brand, I always prefer to ignore the printserver software and just ADD a TCP/IP Port.
Open Control Panel
Open Printers
Right-click: Server Proprieties
Add TCP/IP Port
put the IP address and select option "Print Server"
That's it.
now, just add the printer, manually select the port you've just created.
Jul 12, 2009 | Edimax Computers & Internet
Edimax 6215 - Printserver doesn't work
if your usb light is not lit-there's a chance that your usb led is busted, usb cable is defective or printserver is defective itself.
if your going to connect your printer directly to your pc using the same usb cable and if it works that way. then it could be that your printserver is not working fine.
Dec 05, 2008 | Edimax 4 Port Wireless AP Broadband Router...
Linksys Wpsm54G print sever
about installing the printserver, you can actually make this work using TCP/IP, so that the print server will not be driver-dependent, just the connection.
BUT, using TCP/IP will only allow you to print through the printserver and not COPY, SCAN or FAX through it.
if you have other questions just lemme know
Sep 12, 2008 | Linksys WPSM54G Print Server
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
Jun 27, 2008 | Edimax (PS-3205U) Print Server
Print server problem
I sorry but I am the similary problem whit my edimax equimed , what i can do , im dont print whit it.
Dec 29, 2007 | Edimax BR-6104KP Router (BR6104KP)
Edimax PS 3100A+ (PS-3100A) Print Server Logo
124 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
