Question about Clarion M475 CD Player
AMP GUARD ON
I HAVE A JEEP AND THE GUY INSTALLED THE STEREO AND ABOUT 3 TO 5 TIMES MY AMP GUARD COMES ON BUT THE STEREO IS LOSE IN THE DASH AND I USUSLLY WIGGLE WIRES AND IT PLAYS NO PROBLEM. LAST NIGHT I HAD A 6 SPEAKER STEREO BAR INSTALLED AND I HAVE POWER, IT PLAYED FOR A SECOND AND THE GUARD CAME ON. I AM SICK OF THIS NO ONE CAN HELP ME CAN YOU,
  • TKEEN Apr 22, 2009
    TANK YOU, BUT I CALL THE GUY LAST NIGHT AND THE NUMBER HAS BEEN DISCONNECTED, I WILL FIND HIM BUT
    I WANT TO USE MY JEEP THIS WEEKEND AT THE BEACH AND I NEED JAM.
    SO THANKS FOR YOUR HELP AND I WILL BACK TRACK ALL WIRES.
    President:
  • 2,992 Answers
I'd say go back to the guy who installed and get him to do it right. He's either left some wires exposed so they are intermittently touching, or has an open connection to one of the speakers. The amp will shut down to protect itself. He may also not have wired the speakers correctly. Some systems don't work unless both hot and ground wires run directly to each speaker. Some installers run only a hot line and use the car body for ground. At higher powers this can cause amp shutdown or keep it from working at all. In any case the installation wasn't done correctly.
Posted on Apr 22, 2009
Why my stereo wont work all of the sudden?
Hi David
It would be rather difficult to diadnose the problem while in the dash with various unknown wires connected at the back.
I think your best bet is to take the Stereo out of the dash & bench test it.
Or get the service people or car radio installation guy to test it as it might be shot & need replacing anyway.
Cheers
Dec 28, 2015 | 2006 Mitsubishi Eclipse
Dash light doesn't work
Check fuses for dash light / instrument display. If the fuse is good, you may want to check if stereo share an illumination wire with dash. You may have broken the connection behind stereo.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Jan 06, 2014 | 1992 Honda Civic
My dashboard and gauges keep flickering on and off
sound like you have a lose connection it could be the cables on to the dash or the socket it fits to. you would need to remove the dash and clean the connection and re fit it. if you push on the dash does it stop. ? just check this first as some times its just a tiny amount of play in the connections that's the problem .
Jul 03, 2017 | 2008 Jeep Patriot
I get a pop from the sub when the power comes on.
This is caused because the stereo you have put in, is a high power output, or higher than the factory and puts that extra power into the factory amp systems causing the amp to surge the power to the speaker resulting in the pop sound,most newer cars use a stereo system without an internal amp so as to reduce heat and a external amp in usually under a seat or dash and a high power stereo boost the output of the amp.
Sep 27, 2009 | Car Audio & Video
I have a 98 Wrangler also and my problem is similar, only my dash lights and gauges work but lights on the center on my dash don't work, AC and Heat controls, I have an aftermarket stereo so it actually...
i had some similar problems after i installed my aftermarket radio and i had to go back and rewire it and now the dash works fine. you might want to double check your wireing. i know wiring a stareo is simple but after rewiring i didnt have any more problems with dash lights
May 09, 2009 | 1998 Jeep Wrangler
My Car Stereo Broke
Fuse #13 15 Amp located to left of steering column in dash. Radio, cig lighter and lcd display.
Mar 29, 2009 | 1996 Jeep Cherokee
1989 Licoln Town Car Audio system stopped
depends on whether u installed an amp for the door/dash/rear speakers or not or if it came with a factory amp for these speakers. fuse box is in 1 of 3 places, 1 under the driver side dash, 2 in the glove box, 3 on left side of dash. also if this stereo is not factory u might want to check the fuse on the stereo itself to see if mayb it has gone out or has burned the outputs.
Mar 17, 2009 | 1995 Lincoln Town Car
Amp & subs not working. Do you turn them on by the cd player?
Yes: You need to run the amplfier's remote turn-on to the accessory wire, the red wire of your cd player to the constant accessory 12 volts in the dash.
Feb 06, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I have a DXZ648RMP Clarion car Stereo that says amp guard
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
Jan 23, 2009 | Clarion DXZ648RMP CD Player
KNA G510 update software and add POI file
They either installed it under a seat (easy) or behind the dash (hard). It's probably behind the dash, which means it's gotta be all taken apart. When they were installing the head unit they prolly just stuck it right behind it. So it's basically a pain in the ***. You'd be able to find it by following the wires from behind the unit. I have the same problem, I might just take it to the guy who installed it and have him do it. Call around to different stereo installers, they may charge you like 30-60 bucks to have it done... it's probably worth it considering the pain it is getting the whole dash apart and back together again.
Aug 15, 2008 | Kenwood KNA-G510 GPS Receiver
Clarion M475 CD Player Logo
241 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
