Question about Sony Playstation 3 (PS3) Console
I initially turned on ps3 system on tv. image
I initially turned on ps3 system on tv. image showed but started to fade until eventually nothing was showing on screen. could still hear the audio on tv. I tried with the hdmi cable and tv showed image with hdmi cable. Can i get assistance
  • nolazz Apr 23, 2009
    thanks ill try it.
    Problem Solver:
  • 15 Answers
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Posted on Apr 22, 2009
It won't send video and audio
1 To reset your PS3 back to its original settings go to options. Select system settings and click reset system. WARNINGFollowing these directions will wipe ALL data from your PS3 system. Do NOT do this,
(this will reformat the HDD)
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
3 After you complete the operation and restart the system, the initial setup screen will be displayed. Follow the on-screen instructions to perform initial setup of the system software. Note that performing hard reset on your PS3 will return your password to 0000. However, note that all settings other than the password will also be reset. Once these settings are reset, they cannot be recovered.
Nov 25, 2013 | Sony Play Station 3 System Backpack For...
Cant hook up my ps3 to the tv ? tried all 3 input outlets and nothing tried hooking it up with a dvd player and still nothing ?
The ps3 has 2 output modes, hdmi and composite or component. For example if you started with composite and switched to hdmi the screen would show up black. The way to select the dif output is to press and hold the power button until you hear a second beep, this should put it on the proper output. Hope this helps and is the only thing I can think of if your tv is properly working.
Aug 23, 2011 | Audio Players & Recorders
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Sony ps 3 won't show initial screen. turns on/grn light is on indicating but nothing happens/ have chgd the rca cables/ chgd tv's/made sure not dusty chgd all inputs/still no resp//any ideas? also, no...
Turn off the PS3. Press the power on button (the system will beep) and hold it down for approximately 5 seconds until you hear a second beep. This will reset the video to the default. You should get a low resolution screen and be able to log on and reset the display to the desired settings.
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Image n sound
with the system off-hold the power button on until you hear the second beep-this will configure the system with your tv
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
PS3 start screen will not show up on my TV
I had this problem before. I messed with the settings on my PS3 and My TV until the settings matched. My PS3 would show the home until I loaded a game. I turned off then on my PS3 to get to the settings. My TV manual had the types of videos it supported so I went with the second to highest setting it supported and it worked. Hope this helps.
May 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not show on screen
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the initial beep and wait for a max of 1 min and initial set up screen should appear
Apr 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on, but does not show nothing on tv, game is inserted
Hold down the power button until you hear 2 beeps. It should reset the video.
Mar 23, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
105 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
